2009 Subaru Legacy Cyl 3&4 Misfire @ 4,000 rpm
  • subaru
  • subaru's Avatar Topic Author
9 years 6 months ago - 9 years 6 months ago #8034 by subaru
Hi everyone,
I have had CEL lighting up only at 4000 rpms in parking or in any gear. Idling is fine. Codes are P0303 & P0304
Replaced spark plugs, coils and wires, tested compression (150 psi on all cylinders), tested oxygen and knock sensors.
Fuel trims seem to be normal, ST 0% and LT from -1 to -4 %
Mechanics I've been to fail to find the problem because they don't have any advanced diagnostic tools like oscilloscopes and dealership asks for too much money to find the problem.
Maybe someone can recommend a service shop that can diagnose the problem for fair price.
I'm located in Los Angeles, California.
2009 Subaru Legacy 2.5L non-turbo 120,000 miles
Thanks!
Last edit: 9 years 6 months ago by subaru.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 6 months ago #8037 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2009 Subaru Legacy Cyl 3&4 Misfire @ 4,000 rpm
injector balance test done?
9 years 6 months ago #8042 by borntoroll
Replied by borntoroll on topic 2009 Subaru Legacy Cyl 3&4 Misfire @ 4,000 rpm
freeze frame data?
  • subaru
9 years 6 months ago - 9 years 6 months ago #8052 by subaru
@borntoroll,
Freeze frame report generated by Torque for Android
Vehicle VIN: 4S3BL616897218861
Vehicle Manufacturer: Subaru
Vehicle Calibration ID: EZ1
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 83.529 %
Engine Coolant Temperature = 82 °C
Fuel Trim Bank 1 Short Term = -2.344 %
Fuel Trim Bank 1 Long Term = -4.688 %
Intake Manifold Pressure = 12.183 psi
Engine RPM = 4,883.5 rpm
Speed (OBD) = 89 km/h
Timing Advance = 18.5 °
Intake Air Temperature = 27 °C
Mass Air Flow Rate = 93.9 g/s
Throttle Position(Manifold) = 39.216 %
Fuel trim bank 1 sensor 2 = 0 %
Run time since engine start = 239 s
EGR Commanded = 0 %
EGR Error = 0 %
Fuel Level (From Engine ECU) = 88.627 %
Evap System Vapour Pressure = 40.75 Pa
Barometric pressure (from vehicle) = 14.504 psi
Voltage (Control Module) = 14.004 V
Engine Load(Absolute) = 79.608 %
Commanded Equivalence Ratio(lambda) = 0.909
Relative Throttle Position = 27.451 %
Ambient air temp = 23 °C
Absolute Throttle Position B = 51.373 %
Accelerator PedalPosition D = 36.863 %
Accelerator PedalPosition E = 36.863 %
End of report.
  • subaru
9 years 6 months ago - 9 years 6 months ago #8054 by subaru
@cheryl hartkorn,
Not done. But shop made injector pulse test with Snap on tool I think. They said that injectors are good but they didn't take them off so it might be not completely reliable info.
My other thoughts based on info I found on the web were misadjusted valves or faulty torque converter.
Thank you for trying to help!
9 years 6 months ago #8059 by borntoroll
Does it feels likw its missfiring or only cell lights? 2 cyllinder missfire with 4 cyllinders totall must be shaky
  • subaru
9 years 6 months ago #8062 by subaru
@borntoroll,
Only cel light. Engine runs great, no shaking.
9 years 6 months ago #8066 by Tyler
subaru wrote: @borntoroll,
Interesting. :huh: Makes me wonder if the PCM is falsely flagging misfires because of a software error. The freeze frame fuel trims back this up to a degree, since they show no excessive correction. I've seen this on GM and Chrysler vehicles in the past.
Wondering if a good ol' battery disconnect would be a good idea. :blink: Assuming that the PCM has incorrectly learned a misfire profile, and would benefit from relearning.
  • subaru
9 years 6 months ago #8077 by subaru
@Tyler,
I had replaced the ECU and it didn't help. Also I had car relearn idle multiple times by clearing the codes too.
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
9 years 6 months ago #8082 by Ro-longo
Replied by Ro-longo on topic 2009 Subaru Legacy Cyl 3&4 Misfire @ 4,000 rpm
Does this vehicle have VVT? I have seen low or poor oil condition cause misfire at higher rpm on some Subaru's . Also, has the engine ever been swapped?
  • subaru
9 years 6 months ago - 9 years 6 months ago #8083 by subaru
@Ro-longo,
Yes the vehicle has VVT.
Funny you asked, the engine was swapped from Outback with 100,000 miles on it, but it's the same engine.
Had to replace old engine because I destroyed it, I went 110 mph on the freeway and i think i red zoned it (instant performance loss and loud knocking sounds). It also had about 100,000 miles.
I changed oil many times, (every 3,500 miles) getting oil level checked every 1,000 miles. I have to add a quart of oil every 1 thousand miles, but recently I think engine started consuming less oil (1 quart on 2 thousand miles). One explanation would be that the engine was not running for a while until I installed it and piston rings got back to their working shape. I put about 20,000 miles on new engine.
Thanks!
  • Ro-longo
  • Ro-longo's Avatar
9 years 6 months ago #8084 by Ro-longo
The reason why I asked about the engine swap was that I was thinking it might have the wrong cam or crank reluctor and confusing the PCM, but you mentioned you have had this engine in for 20k. So I think that can be eliminated. I would check the main engine harness connection for any signs of corrosion or fluids. Also make sure all your engine grounds are clean and tight. Next you might want to try to run some oil cleaner though your engine and some fresh oil and a good quality oil filter.
The following user(s) said Thank You: subaru
  • subaru
9 years 6 months ago #8088 by subaru
@Ro-longo,
thank you, will do all that!
9 years 6 months ago - 9 years 6 months ago #8094 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2009 Subaru Legacy Cyl 3&4 Misfire @ 4,000 rpm
Firing order is 1-3-2-4 so 3 & 4 are 360 crank degrees apart but on different banks.
That combination tends to make me thing crank sensor related issue, istr it is a 2 wire inductive sensor it might be worth checking it out and the associated wiring.
Last edit: 9 years 6 months ago by Andy.MacFadyen.
  • subaru
9 years 6 months ago #8111 by subaru
@Andy.MacFadyen,
thanks for response,
i will try to check this sensor and its wiring, but unfortunately i do not have an oscilloscope
and every car service shop i've tried to contact doesn't have it, they just want to replace parts hoping it will solve the problem but are unable to locate and diagnose the actual problem
9 years 6 months ago #8117 by borntoroll
Andy.MacFadyen wrote: Firing order is 1-3-2-4 so 3 & 4 are 360 crank degrees apart but on different banks.
Good point, wish ts had oscilloscope. Also unbalanced flywheel is believed to cause "missfire"
  • subaru
9 years 6 months ago #8127 by subaru
@borntoroll,
If flywheel were unbalanced wouldn't I feel vibrations?
9 years 6 months ago #8128 by Andy.MacFadyen
Is this a manual transmission car ? Is the flywheel the one that came with the engine? Is it a Dual Mass Flywheel ? DMF can throw out a lot of metallic debris when they start to fail.
  • subaru
9 years 6 months ago #8129 by subaru
Andy.MacFadyen wrote: Is this a manual transmission car ? Is the flywheel the one that came with the engine? Is it a Dual Mass Flywheel ? DMF can throw out a lot of metallic debris when they start to fail.
It's an automatic transmission. Flywheel wasn't changed. I'm not sure if its a dual mass, googling my cars flywheel didn't show me that.
9 years 6 months ago #8131 by Andy.MacFadyen
An automatic won't have a DMF the mass of fluid spinning round in the torque converter has a similar vibration damping effect.
Time to create page: 0.424 seconds
