Nobus
  • stephen.bryer
  • stephen.bryer's Avatar Topic Author
4 years 8 months ago #54201 by stephen.bryer
Replied by stephen.bryer on topic Nobus
Do I need to be disconnecting bat each time to reset
  • stephen.bryer
4 years 8 months ago #54202 by stephen.bryer
Replied by stephen.bryer on topic Nobusguves
Yes motor turns over slow with hot batt and no start then with koef after few seconds it dings three dings and the odometer reads nobus. Also I ran cluster test or something like and held button in turned koeo it gave 920 950 999 codes
  • stephen.bryer
4 years 8 months ago #54203 by stephen.bryer
2v on pin 3.
4v on pin 6
2v on pin 11
12v on pin 16
0pen between 6 and 14
4 years 8 months ago #54214 by fixn_junk
Replied by fixn_junk on topic Nobus
Based on your original post I would return to the scene of the crime. How severe was the damage to the crank sensor wiring? If the wires were severed make sure all wires are connected to the proper location. Also make sure nothing is shorted where the damage was. Make sure the crank sensor isn't damaged also. If I'm not mistaken, ignition timing is set according to the crank sensor. No crank sensor signal no spark. If the wiring to the crank sensor is shorted it can cause issues in other areas. Any time I tear into something and have a new problem when I'm done I always go back over my work until I find what I did wrong.
  • stephen.bryer
4 years 8 months ago #54225 by stephen.bryer
Man I appreciate it and im going there now to take a look again . Yesterday I got frustrated with not knowing what and gently unplugged and relocated the lower harness and the crank and cam and one sensor I guess temp between the two going into intake I have all the connectors up where I can see and get good contact on and trying to get answers but between pins 6 / 14 it is open with 0 ohms I have a boost pack and been trying to keep battery up and I was getting a 5 v ref on my o2 connector and three different ground s I think with different ohms I wrote it down but don't have what they where I know it was like 52 46 10 ohms on that on 4 pin connector and one was 5 volts and the park neutral sensor was 12 on two wires and ground 2 ohms i believe so give me a min I'll let you know I'm there and at vehicle
  • stephen.bryer
4 years 8 months ago #54226 by stephen.bryer
Is that because of the two 180 ohms resistors I'm bcm ran together
  • stephen.bryer
4 years 8 months ago #54232 by stephen.bryer
Hey I haven't gotten to check if my adapter will work again but did get 2v on the 3 and 11 wires so it may be com with it now I don't know why I didn't key to that but I can't make it to the truck today I'm sorry I did however yesterday unplugged all I could on bottom and going to yrans and crank cam and oilpressure sensor and had checked connectors pins for voltages and I all of sudden get back 5 instead of 4 on refs kinda I got 12 on two wires going to park sensor and o2 sensor has 5 ref and three pins ohm to ground 52 47 and 10 ohms on them and no 12v to trans on red wire pin 1 or 5v on pin 2 and 5v on pin 8 for some reason and I had been getting 4 ref on tps and 1v on its bk/wt wire but unplugged all the rest and got 5 v back and lost the one on ground
  • stephen.bryer
4 years 8 months ago #54282 by stephen.bryer
61 ohms between 3 and 11 check engine lights up yes and it's in the circuit I'm starting to see ot from diagram but no com yet with torque I attached pics of dash
  • stephen.bryer
4 years 8 months ago #54288 by stephen.bryer
OK im here at truck
  • stephen.bryer
4 years 8 months ago #54290 by stephen.bryer
I unplugged the map and get 4volts on the two wires and 0 on ground koeo and 12 volts to ac on both wires
  • stephen.bryer
4 years 8 months ago #54293 by stephen.bryer
Correct no rpm cranking so I need to check unplugged from sensor ? And koeo .I'm getting. 5 volts on oil pressure sensor and 4 volts on two for crank sensor
  • stephen.bryer
4 years 8 months ago #54294 by stephen.bryer
OK I checked the p / n safety sensor and it has three wires and two have 12 volts a brown with green stripe and a black with white stripe and the
  • stephen.bryer
4 years 8 months ago #54296 by stephen.bryer
Please let me know something I am in cold out here and raining now so I'm trying to get it done but I have to leave at one today and im not sure about tomorrow. I will try but my lady is not happy at all abiit me working on it now and stopped loving on me and being nice because 8 even brought it up because she don't get it why I don't know .I usually do or I findout because I want to know and understand why but I have taken so long man I may get divorced before I can hear it start lol
  • stephen.bryer
4 years 8 months ago #54298 by stephen.bryer
I started a job at Expert Collision and it may be a great chance for me to get alot of hands 9n working im replacing parts and blocking the vehicles that come in and I like it but it's going to effect my time to get to be here and find problem. I thank you all so much for help and trouble with getting my stuff posted back
  • stephen.bryer
4 years 8 months ago #54299 by stephen.bryer
On eight pin to transmission on eight I got 4 volts and it is purple solid I am getting 4 volts on orange solid and 0 volts on orange black pin 2 wire and 0 volts on red solid pin 1 just for your ref
  • stephen.bryer
4 years 8 months ago #54322 by stephen.bryer
I'm sorry I had to borrow my car from my girl yesterday and I only had till one and I didn't mean to sound rude or anything but like right now my neighbor is drunk and calling me asking about his truck because it is taking me longer to give truck back to him and it's very frustrating with him and like that so I have fifteen missed calls and I'm going over to look at it if I can and that's what I said to him I had problems with my own ride and found battery post broken all the way around and used soldering iron to fix and replaced electrolytes and charging but I have been without wheels and worked thus and fri and back mon so it will be after five if I can even get to it . So if I can I will go today and try before dedicated to my new job .L have worked for .yself or kinda running maintenance for a guy and have this gf wanting me to have more income and tabs lol but I'm happy to make them happy and am not . I'll check back soon
  • stephen.bryer
4 years 8 months ago #54327 by stephen.bryer
Not going tonight but ll try again tomorrow afternoon .I need to know does the speed sensor in rear-end in circuit with our crank and cam and tps I'll unplug and try to isolate .and I got a new crank sensor and will install it the shield was gone on the wires of the old one and bear and almost broken at sensor so it wasn't long for replacement thanks for your help hope you have good supper bowl and don't drink too much lol
  • stephen.bryer
4 years 7 months ago #54677 by stephen.bryer
Hey guys I'm here at truck today and I put hot battery on it and tried it but just whirls around and no cranke.So I dont know my snap on scan tool won't communicate with it either .I keep getting no bus and all three lights light up but no com with adapter either. I am lost and dont know what to do with it
  • stephen.bryer
4 years 7 months ago #54678 by stephen.bryer
I'm sorry but I barely have time now that I'm working and don't get home till 530 and that's 20 moles from this truck and I'm so perturbed by the fact i don't know what it is that's wrong that I'm trying to find someone I can pay to get it running and be done with it .I hate telling the owner it's still no go and have to look at him and see him so let down that he won't have a ride again and have to wait till next time I can get over to try or check to get it running .I want to open up my sks on it till it don't ding anymore .
  • stephen.bryer
4 years 7 months ago #55132 by stephen.bryer
I have been trying to make it over and get his truck running but no com with scanner at all and it works for all the other vehicles I use it on .I need help because I feel lost like I don't see it and I know it is crazy but it has started a rip in my relationship with my soon to be ex I fear .So I'm trying to get it to run and drive out of my life
Time to create page: 0.389 seconds
