Really high Fuel trims
  • Username
  • Username's Avatar Topic Author
4 years 8 months ago #54065 by Username
Really high Fuel trims was created by Username
Hi I have a 1998 GMC 5.7 vortec. When Its started from cold to around 185° the fuel trims are normal on bank 1 an a little high on bank 2 LT 10.4 ST 1.7 but when I start driving and it gets to 194° and check them again bank 1 is normal but bank 2 is LT FTRM+25 and ST FTRM+26.6 at idle an only goes down a couple number when rev up to 2500 rpm .any advice would be really appreciated. Please and Thank you
4 years 8 months ago #54066 by ontheriver
Replied by ontheriver on topic Really high Fuel trims
Check the upper intake manifold bolts, any loose? If not, spray some carbclean at bank 2 intake gasket, watch trims or listen for rpm change, could be heat expansion at intake causing a air leak
