2009 Nissan Murano ABS/VDC dash lights are on.
  • dennis524
  • dennis524's Avatar Topic Author
4 years 8 months ago #53964 by dennis524
Please Help!
Got a 2009 Nissan Murano SE with the 3.5 engine. Problem is the ABS and the VDC dash lights are on.
I use a Launch X-431 V+ scanner and I get three codes: C1162, C1161, and C1160. From what information I can get
researching the C1160 code it sounds like the "DECEL G SEN Set needs to be calibrated. The best I can tell the scan tool doesn't
give me this option. I try to erase the codes to see if they come back but they won't erase. This is my granddaughter's vehicle and just before she bought it they put new front brakes on it. After about two days driving it to school is when the lights came on.
What should be my next step? Thanks for any help.
Dennis
4 years 8 months ago #53965 by oneel998
Replied by oneel998 on topic 2009 Nissan Murano ABS/VDC dash lights are on.
identifix says to recal your steering sensor.
  • dennis524
4 years 8 months ago #53972 by dennis524
Replied by dennis524 on topic 2009 Nissan Murano ABS/VDC dash lights are on.
Thanks for your response but I already did that.
Under the special functions that was the only option I had.
I think that I did it correctly but I'll try it again and see if it helps.
Thanks for your time.
4 years 8 months ago #53975 by oneel998
if you did and the fault returns, graph the signal and watch for drop outs.
go all the way right and count the turns, then all the way left and count the turns they should be even. if that passes i would r&r angle sensor
  • dennis524
4 years 8 months ago #53977 by dennis524
OK that sounds like a good idea.
I replaced the battery hoping that would help but it didn't. It needed one anyway.
I'll post the results when I get it done.
Thank you.
4 years 8 months ago #53978 by ontheriver
Replied by ontheriver on topic 2009 Nissan Murano ABS/VDC dash lights are on.
Google, NTB-10-113
  • dennis524
4 years 8 months ago #53980 by dennis524
If I understand the bulletin it means that I would have to take it to a dealership
service department to reprogram the bcm. I was hoping to avoid that and be able to
do the repair myself. But it is what it is and if the steering recalibration doesn't work I'll take it in.
Thanks again for help. I came to the right place.
4 years 8 months ago #53981 by oneel998
good find. i under why didnt that come up in service data?
  • dennis524
4 years 8 months ago #53984 by dennis524
I did the check on the steering sensor and all looked good.
I did a price check on that sensor just incase and it's just under $1000.00
Going to follow that TSB and have the BCM looked at.
Thanks all.
Dennis
4 years 8 months ago #53987 by oneel998
for 1000$ i would also program the bcm at that point
