engine cranks no start...
  • braddah
  • braddah's Avatar Topic Author
4 years 9 months ago #53773 by braddah
engine cranks no start... was created by braddah
Aloha, Call me Braddah.
I have a 2014 Mitsubishi Outlander GT, V6 engine.
Problem is it cranks, has spark, is getting fuel (never check fuel pressure because I can smell the fuel after each try)
I am not getting any trouble codes (OBD) when I turn on the Key there is no check engine lite at all, and the RPM gauge does not move when cranking. I saw on one YouTube video when there is no response on the tac that the cam sensor was bad. I replaced it and there was no change. Came across the Scanner Danner video's and got his online book. I am still researching his book. looking for a direct line to trouble shoot this problem. Thanks, in advance for any directions on this task.
4 years 9 months ago #53778 by Cheryl
Replied by Cheryl on topic engine cranks no start...
Can you communicate with the car through a scanner?
The following user(s) said Thank You: braddah
  • braddah
4 years 9 months ago - 4 years 9 months ago #53780 by braddah
Replied by braddah on topic engine cranks no start...
I don't own or have a scanner, just a OBD tester. I do have a code on the seat belt but northing relating to the engine not starting.
I am not sure how to get around this platform.
just to let you guys know the car finally started, I didn't do anything except hand choked it when it sounded like it wanted to start. (have no idea why that worked) It is running smooth now. still troubled that it started? But I guess I'll just have to wait and see if the problem returns. Still not getting the check engine icon to lite up with the key on or any other time?????
Last edit: 4 years 9 months ago by braddah. Reason: don't know how to add to this post.
