1995 Ford 150 5L 302. EFI , 166k miles- why does the engine die after warm up?
  • Sfezler
  • Sfezler's Avatar Topic Author
4 years 9 months ago #53648 by Sfezler
Steven here- thanks for previous suggestions. Symptoms: Trk was a work horse for 2 years. Dashboard engine light on & off for the 2 years. 1 month ago, engine died. Sputtered and spit like fuel issue; then died. THEN after cooling down, starts right up until warm then starts to miss, sputter/spit (no back fire) and dies.
Changed in-tank fuel pump, fuel relay, in-line fuel filter, thermostat on radiator, plugs & wires. Cleaned most connectors visible.
1. Truck starts, runs, now has a hesitation (popping noise- can heard almost like a backfire but similar to timing needing adjustment) BUT warms up and dies. Double checked correct plug wiring sequence from Distributor to plug is correct. (New sound/new issue)
2. Using Ford OBD 1 Code Reader (key on/engine off) I only get code 121 ‘Closed Throttle voltage higher or lower than expected.’
3. Used an old plug to test for spark. It sparked but not on every full crank of engine turn over.
I am at a loss for next steps. Any advise is welcomed. Steven
4 years 9 months ago #53649 by Deth39
Don't know to much about the old Ford OBD1 system. However with this code, a quick and dirty test I think is to unplug and see what happens. If runs smoother, then I'd check the wiring and voltage at the TPS. Hope this helps.
  • Sfezler
4 years 9 months ago #53650 by Sfezler
The Code Reader is in Engine off position.
What does TPS stand for.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 9 months ago #53653 by VegasJAK
Throttle Position Sensor.
  • Sfezler
4 years 9 months ago #53654 by Sfezler
Excellent quote about wisdom out!
My brain is jelly but I am still standing!
Went she warms up, gets a little rough & plays dead until she’s cooled off to once again, warm up, be rough & die!
I don’t know next steps yet. Again, thank you
  • Sfezler
4 years 9 months ago #53655 by Sfezler
I am to unplug TPS while the engine is running? Sorry, newbie working hard to understand EFI and car parts.
I appreciate your response.
4 years 9 months ago #53662 by Deth39
I would unplug it, then start it up. Might run a bit rough since the TPS is a input sensor. However the computer should have a default strategy it will use. Maybe not as fancy new ones, but should still be there. The idea with it unplugged, if the engine stays running even when warmed up. We can narrow down what's getting hot that will cause the shutdown.
  • Sfezler
4 years 9 months ago #53676 by Sfezler
I replaced the TPS & cleaned the throttle body.
Can’t tell you why but all three (3) wires had any coating 1” up to the sensor.
(3 bare wires)
The Ford Code Reader OBD1 does NOT show code 121 (TPS) since it was replaced.
Good thing!
Next challenge is two (2) other codes indicate the PIP & EGR. I believe the EGR opens/closes by testing it unplugged and then plugged from start up.
Started great plugged. Trouble starting unplugged.
Still studying about the ICM relationship with TPS, EGR, PIP, & other components.
Open to suggestions.
