2013 Honda Accord with code P0087
  • Da Beginner
  • Da Beginner's Avatar Topic Author
4 years 9 months ago #53470 by Da Beginner
2013 Honda Accord with code P0087 was created by Da Beginner
Hello everyone. Okay so I’m working on a 2013 Honda Accord with the code p0087. This is the codes p0087 and p the high pressure fuel pump was changed and the code did go away there’s no code for the fuel fail pressure sensor. The voltage output from the Solenoid on the high pressure pump is 2.9 volts. I will try and upload the freeze-frame to see if that helps with any feedback. I’m not sure if to test the camshaft or where to go next, so any or help help will be greatly appreciated.
