03 Ford Explorer XLT C1175 plus a ton of codes
  • Dtnel
  • Dtnel's Avatar Topic Author
4 years 9 months ago #53425 by Dtnel
Have a C1175 plus a host of other codes. Right now I am focused on the ABS system. I did some keys for the owner, programmed them to the vehicle. If I notice dash lights on in the car I scan the computer and let them know if it's something I do, educate them a little if they ask questions such as will it hurt, etc.
Their new driver in the family is driving this car. I told them with the ABS the ABS won't properly engage as they were concerned about this. I told them they could teach him the old school way of pump let off pump let off pump and let off but they seem to want this fixed.
I came home and unbeknownst to me he had sent me a text saying they wanted it fixed but I didn't want to call him back with the estimate until I made sure I didn't jump in the rabbit hole.
My guess is the 1175 code it's probably tied to the other break codes as well being that if the left rear wheel speed sensor wasn't working properly it would set other systems off.
I told him I'd need about an hour to diagnose it and if it's just a sensor or whatever we could take care of that.
It gets better though because he said that he had noticed a light on so he replaced the front ABS sensors and then he has to get the bearings out on the rear ones as well. Not familiar with this system I just continued to listen.
He said he had the wheel bearings that he had to do on the rear but they were a pain in the butt. So I get home and I look at wheel bearing information and it seems that these wheel bearings are the press in style so I am thinking maybe he bought the whole hub assembly with the wheel bearing and everything.
So now I need to get back and see what he has for parts which I will gladly change him but I won't warranty the labor on the parts being that the parts were supplied by him cuz I don't know if he got Timken or other cheap bearings as in who knows people buy stuff online all the time that's cheap, not good and doesn't last very long and I don't want to mess my reputation up over something like that because someone has a bad part and then I want to charge them to fix it and they leave me a bad review on Google or Facebook.
Then I that thing into the last four that I recall had a wheel bearing which was a 2011 Ford Escape and I recalled the ABS sensor being separate from the vehicle wheel bearing.
I'm going to do some more digging but I just kind of wanted your guys thoughts on if you felt that 1175 would be causing the other ABS codes. All of the codes are in the attached photos.
Also if you guys would and want to put your thoughts on some of the other codes as well that you're seeing there because 12 codes makes me wonder. I do know they replace the battery about a week or so ago and I also know that day or I should say that young child of theirs had a small fender-bender which I am guessing he probably smashed a wire for the airbags but the airbags did not deploy so it must not have been high speed enough.
Just as you guys can see I did erase the engine codes after doing the keys because I had another issue there that I had that I forgot to do that had a key function so I had to go in and do some key programming modification in the chip that I program to the immobilizer, make it think that I hadn't deleted the keys on a AKL even though I had but it has 2 keys in the IMMO status now as I cut, replaced some as well.
Anyways the thoughts from everyone are welcome plus our knowledge here in the forums will help grow the forums for future people down the road.
  • Dtnel
4 years 9 months ago #53429 by Dtnel
Mods let's keep this one please and I'll add the photos. Thanks! Dale
  • Dtnel
4 years 9 months ago #53430 by Dtnel
Here's the photos. Hope they load properly.
  • Dtnel
4 years 9 months ago #53431 by Dtnel
Well that didn't let me add it though it selected the photo, went in the add mode then even showed it in my window where attachments would go but it had 2 other boxes with other wording, etc that came up. I'll try to get a screenshot and get it up on this post
  • Dtnel
4 years 9 months ago #53432 by Dtnel
Seems to be adding thru TapatalkPro though about a 5 step process.
Would probably add more if could resolve this. Will try to get a screenshot uploaded as well.
Sent from my SM-N986U1 using Tapatalk
  • Dtnel
4 years 9 months ago #53433 by Dtnel
Here's the photos from the Browser way in Google Chrome.
Maybe a mod could give these, forward them to their forums Tech guy unless someone else has a solution for this issue.
This is sent from my TapatalkPro once again.
Attn Mods, if you need to remove photos to clean thread up feel free. Thanks! Dale
  • Dtnel
4 years 9 months ago #53434 by Dtnel
Well that didn't work either. Gonna try again.
  • Dtnel
4 years 9 months ago #53435 by Dtnel
Well that worked from the tapatalk using the long convoluted version then having to select local gallery one photo at a time while selecting it, when I select send to add the attachment to the post so I can select another it give me a small, Med or original option for photo size and I select medium so that works.
