2007 Scion TC Alternator
- SniperDan
- Thank you received: 28
I was recently troubleshooting an 07' TC alternator, and found one of the wires going back to the engine computer.
They designated the terminal as "M" on the alternator.
Here's what I can tell you about it...
12v pull down design, the engine computer sends 12v to the alternator and the alternator pulses it to ground.
The frequency I measured was 200Hz, and it's duty cycle was ~23%.
My question is this, does anyone know what this circuit is for? My first thoughts was load demand reports to the engine computer, but this frequency and duty cycle had no reaction to increased load demands on the electrical system.
My second thought was maybe this was some sort of fault detection circuit to the engine computer, but I had no fault codes (This alternator was bad btw.) I also looked for any data PID's referencing this circuit but found none (Verus 15.4 was the scan tool used.)
Any thoughts? I'll be uploading the troubleshooting vid on youtube tonight and I'll post a link here so you guys can see what I'm talking about.
~W. Edwards Deming
M is usually Monitor on Denso alternators which like you I normally have assumed is always alternator load feedback from the alternator to the PCM -- alternator pulls down from battery voltage but on the 105amp output ones I have see it is about 80 to 100 hz with a 50% to zero duty cycle depending on load. With a little 100 amp battery load tester on I can draw the duty cycle down to almost zero..
I wonder if what you are see is because the alternator has failed
- SniperDan
~W. Edwards Deming
www.autoelectro.co.uk/sites/default/file...AERegulatorGuide.pdf
- SniperDan
~W. Edwards Deming
- SniperDan
~W. Edwards Deming
This is the after with a functioning alternator:
I've played with this circuit a bit on my Scion xA. Shorted it to ground with a test light, zero codes, charging voltage steady, and no idle change. :dry: They spent the money to integrate the circuit into the car, but don't seem to care much when it's not working correctly. :lol:
Andy.MacFadyen wrote: Very general but this is useful stuff.
This is good stuff.
- SniperDan
~W. Edwards Deming
- Thank you received: 1138
SniperDan wrote: Here's the video I did on this one, I start focusing on the circuit in question around 16:16.
I liked the video, subscribed!
Thanks for sharing.
- SniperDan
~W. Edwards Deming
