Shorted ignition coil secondary winding
- mfceokeeney
4 years 9 months ago #53313
by mfceokeeney
Shorted ignition coil secondary winding was created by mfceokeeney
Can a shorted secondary winding cause a failure of an ignition control module or will only a shorted primary do that? Or either/both? Thanks.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 9 months ago #53338
by VegasJAK
Replied by VegasJAK on topic Shorted ignition coil secondary winding
I'll take a stab at this. Learning from Paul, do not say always or never. I think a secondary could damage a coil, however I think its from the primary. At the collapse of the primary ramp all that build up of energy with no place to go as in an open plug wire that's the most damaging to a coil.
Hope someone else comments. Would like to hear other views.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 9 months ago - 4 years 9 months ago #53346
by juergen.scholl
Replied by juergen.scholl on topic Shorted ignition coil secondary winding
A shorted secondary winding CAN kill an ignition module, reason being the interaction between priamry and secondary causing the current through the primary to raise. Have a read if you`re interested:
researchgate.net/post/What-is-the-effect...ormer-on-the-primary
Last edit: 4 years 9 months ago by juergen.scholl.
- mfceokeeney
4 years 9 months ago #53347
by mfceokeeney
Replied by mfceokeeney on topic Shorted ignition coil secondary winding
I tried that link, but it isn't loading. Is that the correct link? Thanks.
- juergen.scholl
4 years 9 months ago - 4 years 9 months ago #53348
by juergen.scholl
Try the link again, it should work now. AND: a shorted primary will kill a module as well.
(This is prob. one of the most edited posts on the whole forum, not sure why it was that difficult to get the link going :woohoo: :silly:
