Primary ignition waveform
- bruce.oliver
- Thank you received: 88
2001 Accord 3.0 Customer describes what sounds like a misfire. No codes and drives good for me. Dont feel any misfires. Primary ignition looks like this on all 3 front bank coils. 3 rear bank coils looks more like what the sample waveform looks like on the test information. The firing line starts before the voltage drops all the way down. Front 3 the voltage drops past the starting point and all the way to zero then comes back up for the firing line. Are the front 3 coils bad or is this nothing to worry about?
- bruce.oliver
- GeekDIYMechanic
- Ben
- Thank you received: 215
- Ben
bruce.oliver wrote: Yes that's what I'm talking about. The voltage goes down then comes back up. The other 3 coils don't do that. Didn't have much time to look at it tonight. Plan on driving it more tomorrow
OK cool.
- bruce.oliver
It's a 3 wire coil, they have the ICM built in to each coil. I couldn't get my COP probe to pick anything up. I've heard that some people put a plug wire between the coil and plug but I didn't try that.Ben wrote: Also I wouldn't bother looking at primary ignition unless you have a dead miss or your corresponding events with cylinder 1 firing .secondary ignition is where you'll see anything useful when it comes to misfires but even then it can be hard to spot a bad 1
I couldn't duplicate the complaint anyway so not 100% sure it was a misfire.
- Ben
