2017 ram 3500 p0456 hemi
  • Cheryl
  • Cheryl's Avatar Topic Author
4 years 9 months ago #53281 by Cheryl
2017 ram 3500 p0456 hemi was created by Cheryl
Smoked the evap system do not see a leak. Passes large and medium leak test. When I smoke it I remove line from purge go in that way then remove fresh air hose from esim and cap it. So replaced purge and esim to no avail. It’s failing the scan tool test called small leak verification test. What’s the criteria to run the small test accurately. It has a little more than a 3/4 tank of gas
4 years 9 months ago #53293 by ontheriver
Replied by ontheriver on topic 2017 ram 3500 p0456 hemi
Looking around and found there is a pcm update for that code
