Idle surge
  • Throckrocket
  • Throckrocket's Avatar Topic Author
4 years 10 months ago #53233 by Throckrocket
Idle surge was created by Throckrocket
Hi! I have a 2000 dodge ram 5.9 Cummins 5 speed. Runs great for the first 5 mins in the mornings. After 5 mins it idles rough (like a miss) It idles between 800-1200rpm Fluctuating. As soon as I barley hit the throttle or lay into it, the rpms will fall at about 1050 and stay there until i put it in gear then it drops in idle to about 800 rpm. When driving it, it runs just fine, but when I come to a stop it idles high. I had a map Sensor code and replaced that sensor and check engine light went away. What would cause the high idle..apps aka throttle position sensor? Thank you!
4 years 9 months ago #53280 by Chad
Replied by Chad on topic Idle surge
Have you checked for vacuum leaks?
