2003 f150 rough idle high trims
  • HOSS1980
  • HOSS1980's Avatar Topic Author
4 years 10 months ago #53166 by HOSS1980
2003 f150 rough idle high trims was created by HOSS1980
I'm new to the site...
I've been trying to repair/troubleshoot a rough idle and bank 1 lean code, I've done just about everything I've found online to no avail: plugs, 2 new cop's, 2 upstream o2,repaired exhaust leaks,swapped in junk yard mafs (it went rich on bank 2) replaced iac,check fuel pressure 33psi,fuel filter, I'm sure I'm forgetting a few items,
Just spent 2 hours smoke testing again ,because it acts like a vacuum leak....now I'm thinking timing, but want to make sure before I do....
High milage 325k don't know much history on it. It always sets lean code at idle using original maf, but when I put the other on it rich bank 2, both show g/s readings over 0.01 koeo
4 years 10 months ago #53187 by Hardtopdr2
Replied by Hardtopdr2 on topic 2003 f150 rough idle high trims
What engine do you have 5.4 or 4.2?
Fuel pressure was it running or key on engine off? Fuel pressure is low it should be 50 psi. Check fuel pressure regulator by pinching off rubber section of return line and see if pressure goes up if not pump is bad or you have a leak in fuel lines to rail. If pressure drops after key cycled and pump shuts off then you have a leaking injector. if not replace fuel pressure regulator if on fuel rail. If not on fuel rail it will be in the fuel tank with fuel pump. And before replacing pump check voltage at pump with it on to see if it shows less than battery voltage as this can cause a low fuel pressure issue as well.
The following user(s) said Thank You: HOSS1980
  • HOSS1980
4 years 10 months ago #53188 by HOSS1980
Replied by HOSS1980 on topic 2003 f150 rough idle high trims
Truck runs great, just a shaking idle. So I could probably rule out:
Blocked fuel rail,injector,
Unless I've missed something I'm leaning towards cats,or maybe timing set.
4 years 10 months ago #53189 by ontheriver
Replied by ontheriver on topic 2003 f150 rough idle high trims
Can you answer the 2 questions from previous post? And what do the 2 maf sensors read at idle?engine warm and in g.p.s.
  • HOSS1980
4 years 10 months ago #53190 by HOSS1980
It's a 5.4
Had 32psi on rail koeo and running,snap throttle would fetch 35 psi. With regulator vacuum line off it went to 40 psi. Thus was one of the first things I checked earlier in the week ,searched online for fp pressure specs.,and found 28-45 was normal??...so I thought.
When I get home from work I can do more checking.
4 years 10 months ago #53191 by Hardtopdr2
www.eautorepair.net
or
www.alldatadiy.com
Will have everything you need from fuel rail pressure specs to testing components and wiring diagrams. You can get a subscription for a month for 20 bucks or 4 years for $44.
Googling it might get you close but this will be accurate info.
  • HOSS1980
4 years 10 months ago #53193 by HOSS1980
Ok new issue, installed new maf and bank 2 is giving rich code, high negative fuel trims bank 2 ,bank one looks good now.
New maf reads .05g/s koeo
6.71-6.89 idle, surges a little like always
4 years 10 months ago - 4 years 10 months ago #53194 by Hardtopdr2
(albeit it's technically in spec but on the low end )Also fuel pressure spec is supposed to be between 30-55 psi koeo on e series, f series and excursion with the 5.4L 2v. But rule of thumb for most of us is 50 psi on initial turn on and a rest pressure of what the regulator is supposed to regulate to. Typically this rating is on the regulator other wise need to look in service info for it.
Last edit: 4 years 10 months ago by Hardtopdr2.
  • HOSS1980
4 years 9 months ago #53250 by HOSS1980
It's a 5.4
  • HOSS1980
4 years 9 months ago #53252 by HOSS1980
Turns out that cylinders 1,4,5,8
All have 50-90psi,and all others have 175+.....
4 years 9 months ago #53258 by craig anderson
Replied by craig anderson on topic 2003 f150 rough idle high trims
I guess a compression check would be in order for my 05 F250 with the 5.4 3 valve I was able to get the plugs out yesterday without busting them off in there.I did it engine hot with impact wrench. I have 55k miles on the rebuilt Powetrain Poducts engine Sorry you found bad compression but at least you found it. What are you going to do?
  • HOSS1980
4 years 9 months ago #53259 by HOSS1980
Drive it, it runs great, just has slight shake at idle
4 years 9 months ago #53265 by Hardtopdr2
Might just need a valve adjustment with what's going on. 175 plus on those other ones makes me wonder if coolant is in the cylinder or oil or gas.
  • HOSS1980
4 years 9 months ago #53266 by HOSS1980
No sign of oil, coolant, when I pulled intake, and none on the month old spark plugs....on #5 I had compression coming thru intake valve,but the other 3 that had low compression didn't. I didn't know the valves were adjustable on this engine.
4 years 9 months ago #53268 by Hardtopdr2
Yep I should have looked that up but valve lash adjusters and roller followers are known to have the springs weaken (lash adjusters) and bearings fail (roller followers).
the other thing to look at would be cam lobes to see if excessive wear has happened just have to pull valve covers to inspect.
Time to create page: 0.371 seconds
