06 Isuzu HRT 7.8 diesel chassis power windows
- Johnpreid
4 years 10 months ago #53066
by Johnpreid
06 Isuzu HRT 7.8 diesel chassis power windows was created by Johnpreid
I used Danners switch input (pull up) method for the door locks but the power windows are current carrying wires. I actually tested them for continuity. Mitchell doesn’t have the wiring diagrams for some reason. Forgive me if I missed this in the book. I wanted to operate (bypass test) the circuitry but when I unplugged everything and passed 12v with alligator clips and t pins it didn’t work. Just wondering if anyone can comment on that.
How to bypass test non computer signal/current carrying wires. I could be wrong altogether.
Thanks
Thanks
4 years 10 months ago #53073
Replied by Noah on topic 06 Isuzu HRT 7.8 diesel chassis power windows
The window motors will reverse polarity. If I need to prove one I disconnect it from the harness and apply 12v to one pin and ground to the other, then reverse them to operate the motor in the opposite direction.
To test the circuit i plug a head lamp into the current carrying wires and operate the switch. If the circuit is good the lamp will light when you move the switch up or down.
- Johnpreid
4 years 10 months ago #53083
by Johnpreid
Replied by Johnpreid on topic 06 Isuzu HRT 7.8 diesel chassis power windows
How did you hook up the head lamp?
4 years 10 months ago #53085
I use one like this:
I have banana plugs on mine so I can pick the correct terminals out of this kit: www.google.com/url?sa=t&source=web&rct=j...Zqs8bpNNm3t9yNmeIjUk
But you don't need to go crazy, alligator clips will do the trick if you can keep them from touching each other.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 10 months ago #53086
by juergen.scholl
You can disconnect the harness from the window motor and then connect one wire of your headlight into the plug on the harness side while the second lead of your head light goes to ground. Operating the switch then should make the light come on. You would test the second wire in the plug (harness side again) in the same way.
Replied by juergen.scholl on topic 06 Isuzu HRT 7.8 diesel chassis power windows
- juergen.scholl
4 years 10 months ago - 4 years 10 months ago #53087
by juergen.scholl
Noah, I like the "don't tamper" message....
Last edit: 4 years 10 months ago by juergen.scholl.
