Long crank
  • Carstuff
  • Carstuff's Avatar Topic Author
4 years 10 months ago #53026 by Carstuff
Cold start injector information was created by Carstuff
Would anyone know if the cold start injector fires everytime regardless of temperature. I know during cranking the wire shows 12 volts.
4 years 10 months ago #53027 by ontheriver
Replied by ontheriver on topic Cold start injector information
That's the power side, crank only, on ground side, it is controlled by a thermostat or temp. sensor
  • Carstuff
4 years 10 months ago #53029 by Carstuff
Replied by Carstuff on topic Cold start injector information
Would you know if bypassing the thermswitch so it fires every time regardless of temperature would be an issue?
I have a long crank time but if I force it to spray it cranks fine. Or to get it to start normal I have to tap the throttle open a bit
4 years 10 months ago #53031 by ontheriver
Sounds like a bandaid, I would not alter the cold start system, What is the vehicle?
  • Carstuff
4 years 10 months ago #53032 by Carstuff
929 model
I probed the crankshaft sensor during cranking and the pattern was not consistent. New sensor as well same crank pattern.
  • Carstuff
3 years 11 months ago #58796 by Carstuff
Replied by Carstuff on topic Long crank
  • Carstuff
3 years 11 months ago #58878 by Carstuff
Cold start injector isn't firing and it takes long to start up , check put video
youtube.com/shorts/nDwEBLNJn9Y?feature=share
