Ford fiesta 1.0 ecoboost 2013
- Pieter
- Thank you received: 3
4 years 10 months ago #52938
by Pieter
Ford fiesta 1.0 ecoboost 2013 was created by Pieter
Hi. I have a ford 1.0 ecoboost. Came with a p0172 system too rich bank1 and p2196 oxygen sensor signal biased/stuck rich bank 1 sensor 1.
I tested the evap purge valve and going through the duty cycles it would stop clicking. So I changed the purge valve and now it works through the range and stops at 100%.
The stft is at -29 and ltft is 0. And fuel status would go to open loop fault and stft is 0 then and if I give it a rev it would go to closed loop and stft back to -29.
I swopped the injectors out with another set I have in a old head from a motor with piston failure to see if anything changes and nothing. Keeps running rich. Cleaned the maf as best as possible as it is like semi sealed.
Any help would be greatly appreciated. Thanks
- Cheryl
- Thank you received: 215
4 years 10 months ago - 4 years 10 months ago #52942
by Cheryl
Replied by Cheryl on topic Ford fiesta 1.0 ecoboost 2013
What do both oxygen sensors read? What does fuel quality test at? What is fuel pressure spec vs what you have
Last edit: 4 years 10 months ago by Cheryl.
- Cheryl
4 years 10 months ago #52943
by Cheryl
Did you reset keep alive memory
- Pieter
4 years 10 months ago #52945
by Pieter
Replied by Pieter on topic Re:Ford fiesta 1.0 ecoboost 2013
I will see what the o2 sensors are reading, but not sure if all the pid is there for both sensors. As the bank 1 sensor 2 data I found under a different place as the normal live data. Think it's like 06 data under service section on the autel scanner. I will check it all in the morning when I am back at work. Thanks
Sent from my SM-A307FN using Tapatalk
- Pieter
4 years 10 months ago - 4 years 10 months ago #52950
by Pieter
Replied by Pieter on topic Ford fiesta 1.0 ecoboost 2013
Yes. I reset the pcm learned values. Oxygen sensor 1 only shows heater duty cycle and it is at 43% on idle and when I rev it goes to about 50 and on deceleration drops to 35.
Oxygen sensor 2 shows voltage and reads 0.89 on idle and as I rev it drops as low as 0.7
Fuel rail pressure reads 3 Mpa on idle and goes up to about 15 Mpa as I rev it up. Fuel rail pressure sensor voltage is 1.11v at idle and goes up to 3.43 when I rev it up
Another thing I found is that in the freeze frame data it shows ect2 -40 celcius. But I cant find a 2nd act sensor. I only see the 1. Could it be that it is just there for the scantool incase it has another ect sensor.
Last edit: 4 years 10 months ago by Pieter.
- ShafDen
3 years 9 months ago #59567
by ShafDen
Replied by ShafDen on topic Ford fiesta 1.0 ecoboost 2013
What was the issue , did you solv it?
