BMW X5 2001 Camshaft Errors (P0343, P0348)
  • OzBaba1
  • OzBaba1's Avatar Topic Author
4 years 10 months ago #52866 by OzBaba1
Hi there,
I am trying to figure out a way to fix a recent P0343, P0348 errors on my BMW X5 4.4 01.
Basically those errors started happening after I did some valve work. I am in the process of starting the car (I have not attempted yet because of the errors), right now only cranking. What I have done so far:
Firstly, engine is properly timed,
- Replaced the sensors with good ones,
- Tested crankshaft sensor and it tests good (I can see the RPM from my testing computer cranking around 180 rpm),
- I can see using a voltmeter that both sensors send pulse (pull down from 12v to 0 each time it detects the metal part of the pulse sending wheel)
- Tested to see if the signal goes all the way to DME (ECU) and it does,
- Replaced the DME and same errors appeared so the DME should be ok,
Not sure what else I can do at this point. My only concern left is the slightly low battery power as I crank which shows around 11V. Would that affect the DME (ECU) recognizing the signal coming from the sensors?
Thanks in advance for all the help,
Cheers,
Ozzie
  • OzBaba1
4 years 10 months ago #52881 by OzBaba1
Replied by OzBaba1 on topic BMW X5 2001 Camshaft Errors (P0343, P0348)
After doing some reading about DME and other relay issues, I have replaced both of them as well but no improvement.
Basically, every time I crank the engine I get the same errors.
Any other ideas?
Thanks,
Ozzie
  • OzBaba1
4 years 10 months ago #52914 by OzBaba1
The reason was, each timing wheel was slightly off. After adjustment, errors went away..
Thanks,
Ozzie
