1996 tacoma
  • Herc53
  • Herc53's Avatar Topic Author
4 years 10 months ago #52848 by Herc53
1996 tacoma was created by Herc53
I got this 1996 tacoma . And i got a ground at my Sta fuse . Both sides of fuse . I pulled fuse and this ground is feeding E5 pin 11 pin at ECU also it’s sending ground to cluster light and circuit open relay . Black white striped wire . Im not sure if this is right . I replaced my circuit open relay . But this ground is still there . Is this a ground wire or just shorted ?
4 years 10 months ago #52861 by Tyler
Replied by Tyler on topic 1996 tacoma
For our info, what are you using for testing? Power Probe?
With the ignition in any position other than start, it's normal for the STA fuse to show a ground. The ground is coming from the control side of the Circuit Opening relay and the starter solenoid. With the ignition in crank, both sides of the fuse should show 12V.
