1999 Buick Regal GSE
- lovey195
9 years 6 months ago #7468
by lovey195
1999 Buick Regal GSE was created by lovey195
Hey guys I'm new to the diagnostic world with limited experience. I have a 1999 Buick Regal GSE. It randomly shuts off while driving and won't restart for a period. I recently bought a Verus wireless. Several codes came up but I don't believe they would cause the condition that the car is randomly displaying. The first code is for the thermostat. The second is an engine misfire. It didn't tell me which cylinder though. And finally it gave a o2 sensor code. Any help would be appreciated thanks
9 years 6 months ago #7470
Replied by Tyler on topic 1999 Buick Regal GSE
Congratulations on the Wireless!
You're gonna love it.
I agree that those codes are unlikely to be related to your stalling symptom. If you want, you can narrow down that P0300 by going into scan data and checking the Misfire Data list. It'll keep a history of misfires on each cylinder. Follow the one(s) with the highest counts first. What was the O2 code, specifically?
Back to the stalling. I think the simplest way to attack this is to find out what you're missing after the engine shuts off, once it turns into a no start. This has the coils right up front, so spark testing is a cinch. You can even do the patented ScannerDanner Type 2 coil test.
You can also get to the fuel injectors on this one (as opposed to the 3.1/3.4), and use a good ol' incandescent test light to look for pulse (or a noid light if you have one). If you're missing one or the other, then I'd suspect an input problem. If you have both spark and injection pulse, then I'd suspect a lack of fuel pressure. That's our diagnostic 'fork in the road'.
Also, your symptoms remind me of a two-part series Paul did on another GM with a 3.8, check it out:
- lovey195
9 years 6 months ago #7473
by lovey195
Replied by lovey195 on topic 1999 Buick Regal GSE
Thanks for the help Tyler. I'll start there and see what happens the weird thing is Im probably gonna have to drive it for a while. It doesn't do it all the time it could be fine for several weeks. Last time it happened I was near Pittsburgh and had to have a tow. But again thanks for the help
9 years 6 months ago #7477
No problem, let us know what you find! Intermittent problems are the worst.
