2014 Honda Odyssey Charging System problem
  • cracker442
  • cracker442's Avatar Topic Author
4 years 11 months ago #52749 by cracker442
2014 Honda Odyssey Charging System problem was created by cracker442
2014 Honda Odyssey not charging, new alternator was installed but still not charging. When looking at scan data the ELD sensor output drops from 4.9 with key off to 2.8 with engine on, blower, heated seats etc. all on. My question is should it drop lower than that to turn the alternator back to high? The alternator says 99%, alternator control says 14.9 and the signal still says low. Any suggestions would greatly appreciated.
4 years 11 months ago #52753 by Cheryl
Replied by Cheryl on topic 2014 Honda Odyssey Charging System problem
From what you wrote the alternator is already commanded to high with it at 99% and 14.
4 years 11 months ago #52754 by Cheryl
Have you voltage dropped the charging system? What is it charging at?
  • cracker442
4 years 11 months ago #52755 by cracker442
Replied by cracker442 on topic 2014 Honda Odyssey Charging System problem
The voltage is staying at battery voltage even with the command at at 99%. If I unplug the alternator the Alt L signal goes to high and 0%. I am suspecting that we have a defective alternator from the parts store. We had better reading with the old alternator but just wouldn't keep up with a large load on it.
4 years 11 months ago #52756 by Cheryl
Is the battery light on in the cluster? I’m with you them part stores alternators are junk. I’d get an oem if you could. Did you charge the battery up real good or is it dead?
4 years 11 months ago #52757 by Tyler
Replied by Tyler on topic 2014 Honda Odyssey Charging System problem
Voltage drop the main battery cable and the alternator case, with the engine running. 300mV or less.
Then, check the black/yellow at the alt connector for B+. Check the white/green for more than 8V. If those checks pass, your new alt sucks. ;) None of the other wires at the alt will cause a low charge rate.
The ELD may be acting up, but it won't cause a low charge rate by itself. That's why the white/green wire check is important.
4 years 11 months ago #52759 by wowcoop
Replied by wowcoop on topic 2014 Honda Odyssey Charging System problem
The alternator brackets on these are notorious for bad contact particularly the painted ones. Verify that the alternator is grounded before going crazy replacing parts...
  • cracker442
4 years 10 months ago #52821 by cracker442
Thank you all for the tips, after doing the test and reading the post, we determined it was a junk new alternator. The good news we installed a new one today and the van is on the road!
4 years 10 months ago #52823 by wowcoop
good to hear, can't believe how many bad replacement parts are out in the wild these days...
  • cracker442
4 years 10 months ago #52824 by cracker442
Unfortunately this is true. I felt bad for my student that he had to learn the hard way on the cost of a replacement part.
Time to create page: 0.332 seconds
