1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated)
- Mechanic 350
- Thank you received: 15
4 years 11 months ago #52459
by Mechanic 350
1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated) was created by Mechanic 350
All 3 elements for an engine to start are present.
Fuel
spark
compression.
But I couldn't get the car to start. The car is a carburated vehicle. Pounds from an electric fuel pump is 5 psi. I checked for spark again with my test light and spark was jumping to my test light. I took out the spark plugs and they were all wet with fuel and carbon. Cleaned them up and still no fire. If I received spark from my test light, I'm thinking to myself, then there's no need to check the igniter on the vehicle, the igniter is working as it should. What am I missing here?
Fuel
spark
compression.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 11 months ago #52464
by VegasJAK
Replied by VegasJAK on topic 1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated)
Two things come to mind. First is, is the spark. How long was the spark from the test point? You may have spark but under compression it might be too weak.
Second is cylinder wash. With fuel soaked plugs just drying is not enough. Squirt a oil cap full of oil into each cylinder.to restore those cylinders. Smell the oil on the dipstick. If fuel smell you'll need to change your oil.
- Mechanic 350
4 years 11 months ago #52466
by Mechanic 350
Replied by Mechanic 350 on topic 1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated)
The answer to the first questions is no. The spark wasn't that long to begin with.
I also did not add oil to the cylinder. They might contain more fuel than oil. So I will suggest to customer to change oil.
I want to see the spark line as I'm cranking the engine over. But I'm not sure how to hook up my vantage pro so I can see a waveform. Can you assist? and sorry, I don't do this for a living. Just a shadetree mechanic. thanks
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 11 months ago #52470
by juergen.scholl
Replied by juergen.scholl on topic 1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated)
Connect one channel of the vantage to the negative side of the coil and the ground lead to battery negative or a good chassis ground. That way you will capture the primary circuit which will show you burn time, if there is any.
You may want to hook up the second channel to battery positive while cranking, AC-coupled.This will give show you the relative cylinders' compression, just remember that the tdc is indicated by the valley in the trace, not the peak. This second channel will allow you check the spark timing in relation to tdc.
Some other thoughts: Is your fuel ok, no (water) contamination there? What is the story behind, has the car been sitting for a while, did it shut off driving or what ever??
- Mechanic 350
4 years 11 months ago #52477
by Mechanic 350
The fuel checks out ok.
The car was running before, as I was told by the owner. It just recently started doing this thing. Cranking but not starting. I will hook up my vantage pro as you suggested and I will get back to you. Thanks for showing me the vantage pro hook up Juergen
- ksat22
- Thank you received: 9
4 years 11 months ago - 4 years 11 months ago #52499
by ksat22
Replied by ksat22 on topic 1982 Toyota Corolla 1.8 3 TC Engine; cranks but does not start ( carburated)
Fuel, spark, compression and timing. If the spark isn't happening at the right time, it won't start either.
As far as determining spark strength, I like to use one of those cheap, adjustable gap testers (instead of a light) and set it to around what the gap of the plug should be.
Last edit: 4 years 11 months ago by ksat22.
- Mechanic 350
4 years 11 months ago - 4 years 11 months ago #52510
by Mechanic 350
Ok I will do that test. I have that cheap spark tester.
Last edit: 4 years 11 months ago by Mechanic 350.
Time to create page: 0.383 seconds
