2014 Chrysler Town and Country Rocker arm replacement
  • Mitchroberson
  • Mitchroberson's Avatar Topic Author
5 years 1 hour ago #52283 by Mitchroberson
So we had the infamous tick. And replaced rocker arms. But now we are getting the following:
P0017 Crankshaft/camshaft Timing misalignment Bank -1
P000A Bank 1 Camshaft 1 position slow response
P000B Bank1 Camshaft 2 position Slow response
So Which side is Bank 1 that is my first question I always thought it was the Left side as the driver is looking at the back of the engine. And that is NOT the side we did any work on.
i have attached pictures as well as codes.
5 years 1 hour ago #52284 by juergen.scholl
Replied by juergen.scholl on topic 2014 Chrysler Town and Country Rocker arm replacement
5 years 1 hour ago - 5 years 1 hour ago #52286 by juergen.scholl
General rule: cylinder one is the farthest away from the flywheel side of the engine.
Exception: french cars.
Last edit: 5 years 1 hour ago by juergen.scholl.
  • Mitchroberson
5 years 6 minutes ago #52288 by Mitchroberson
Replied by Mitchroberson on topic 2014 Chrysler Town and Country Rocker arm replacement
OK I was wrong it is on the Right side from what I can see in alldata. Must have damaged the VVT control.
4 years 11 months ago #52290 by Chad
I will add that Bank 1 is whichever side contains Cylinder #1.
  • Mitchroberson
4 years 11 months ago #52291 by Mitchroberson
Yep I figured that out after looking at alldata. And am mad as I knew that but my brain is not working today. Thanks
4 years 11 months ago - 4 years 11 months ago #52292 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2014 Chrysler Town and Country Rocker arm replacement
 I also  remember the exception that  proved the  rule the little  French Chrysler-Simca  engine
One trick with Vee engines is the cylinders on nearly all automotive Vee engines are staggered and one bank of the Vee will  be an inch or so ahead of the other bank and that will be bank 1.
Last edit: 4 years 11 months ago by Andy.MacFadyen.
4 years 11 months ago - 4 years 11 months ago #52294 by juergen.scholl
Early childhood memories come back with the Simca 1000 8-).
Later the "big" ones, 1300 and 1500. Not so sure wether its the exception... I got them booked as Belgian?!?
Last edit: 4 years 11 months ago by juergen.scholl.
4 years 11 months ago #52309 by juergen.scholl
OK, big brother GOOGLE told me it was FRENCH indeed.
4 years 11 months ago - 4 years 11 months ago #52346 by Noah
Did you pull the cams to change rocker arms? Just as an FYI for any one faced with one of these, you can do rocker arms without touching the timing.
I think there is another post here somewhere it got discussed...
​​​​​​Or maybe it was a video meet.
Last edit: 4 years 11 months ago by Noah.
