1977 Olds 455, HEI, Fitech, GMC Motorhome, no start
  • guafa
  • guafa's Avatar Topic Author
5 years 4 days ago #52203 by guafa
Hi p55giordano.
Is it possible to keep an eye on injectors/blades while cranking? Maybe they are firing and the engine is getting flooded.
Did you check vacuum/map PID while cranking? If it doesn't change at all, PCM fire injectors with to much fuel.
Maybe a stupid question but here i go. Is the tach line connected to negative coil terminal? PCM "expects" to see a voltage drop from 12v to 0v to fire the injectors.
Try to crank engine with throttle on the floor, so that you can discard a lack of air in air/fuel mixture.
  • guafa
5 years 3 days ago #52226 by guafa
Yes. Should be the falling edge pulse (12v) from HEI system which fires the fitech injectors.
