Charging system voltage
- al514
- Thank you received: 7
5 years 5 days ago #52193
by al514
Charging system voltage was created by al514
Hey all, I'm just looking for some ideas of how much, and what kind of damage will a charging system voltage at 15.5v do after a good amount of time. I don't know how long it had the over voltage condition, it may have been some time, years, months, etc. I don't know if it ever went over 15.5, I guess there's a chance of that, of course customers don't always tell the whole story. And I don't really want to get into all the issues it has now because we'll be here all night, but just some general thoughts where an issue like this could lead to. Thanks much.
- Abe_Lincoln
5 years 4 days ago #52202
by Abe_Lincoln
Replied by Abe_Lincoln on topic Charging system voltage
Personally I haven't seen those voltage levels cause problems except for accelerated battery wear. In my experience I've seen charging voltage issues cause problems exceeding 17-18 volts....computers in cars don't like high voltage, and even higher voltage levels will cause permanent damage.
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 3 days ago #52204
by juergen.scholl
In general life span of components like bulbs may/will be shorted, battery possibly gasses out extremly due to overcharging, exposed to higher than normal temperature will affect adversely is life.....
Replied by juergen.scholl on topic Charging system voltage
What charging system/car specifically are you referring to? Any computer controls involved?Hey all, I'm just looking for some ideas of how much, and what kind of damage will a charging system voltage at 15.5v do after a good amount of time.
- ksat22
- Thank you received: 9
5 years 3 days ago #52205
by ksat22
Replied by ksat22 on topic Charging system voltage
I've heard some charging systems bump the voltage up that high during cold temperatures as part of its normal operation. It might not be the best level to be at that level during the warm weather, but I doubt it'd be catastrophic to anything.
5 years 3 days ago - 5 years 3 days ago #52218
Replied by Tyler on topic Charging system voltage
Higher charging output over months could potentially lead to shorter battery/alternator life? Maybe shorter bulb life, like others mentioned.
Some systems DO intentionally charge at 15.5V, depending on measured battery condition. GM RVC systems, for one.
Last edit: 5 years 3 days ago by Tyler.
- al514
5 years 3 days ago #52220
by al514
Replied by al514 on topic Charging system voltage
I'm honestly not sure if it hit higher voltages, it may have, it was the alternator causing it, not the ecm regulating problem. But it's reading strange data now and completely different codes after the alternator change. Bmw too, so finding service data is not the easiest.
