2004 jeep grand cherokee 4.0 open circuit injector cylinder 1
- beh0038
5 years 6 days ago #52179
by beh0038
2004 jeep grand cherokee 4.0 open circuit injector cylinder 1 was created by beh0038
Im new here. do bear with me. im getting a p201 code . i pulled the wire on injector 1 hooked a test light to it. all the other injection plugs flicker #1 just stays on I traced the wire back to the pcm driver its a white/blue wire I checked it at the pcm with a test light .clip on the test light on the pos and probe on the white/blue wire with the engine running it stayed solid. i then clipped the wire tested white/blue wire at the pcm with the test light. its still solid. I tested the clipped wire to the injector for a ground short it seems to be fine . i then hooked the wire back up and plugged it into another injector a loose one same result. solid light i then probed the yellow white wire next to it suppose to be the control for cylinder 3 it is flickering as expected. the feed wire is fine. at this point im drawing a conclusion that the pcm needs to be replaced. but wanted to ask am i missing something?
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 6 days ago - 5 years 6 days ago #52180
by juergen.scholl
Replied by juergen.scholl on topic 2004 jeep grand cherokee 4.0 open circuit injector cylinder 1
Hi, and welcome.
I understand that you cut the white/blue control wire of injector ·1 at the pcm. With a test light hooked up to B+ with the engine running the light stays on all the time when you connect the tip of the test light to the part of the cut white/blue wire that connects to the pcm. If this is true then yes, the driver for injector nr.1 is shorted to ground.
Last edit: 5 years 6 days ago by juergen.scholl.
The following user(s) said Thank You: beh0038
- beh0038
5 years 6 days ago #52181
by beh0038
Replied by beh0038 on topic 2004 jeep grand cherokee 4.0 open circuit injector cylinder 1
thank you so much i was afraid i didnt explain it enough. but you understood exactly. one more quick question on this model does the pcm need to be flashed or can i pick one up at a salvage
- juergen.scholl
5 years 6 days ago #52183
by juergen.scholl
The pcm does not need to be "flashed" in the sense of programing the calibration/maps into it.
BUT: you will have to "marry" the new pcm to the immobiliser. This basically is writing the vehicle identification number of your car into the pcm. To do so you´ll need a capable scanner, the secret (4 digit) immo pin of your car and - preferably - of the donor car.
- beh0038
5 years 6 days ago #52186
by beh0038
pardon my ignorance but how do I obtain the immo secret pin code for my vehicle and my donor car which im sure will be immobile
- juergen.scholl
5 years 5 days ago #52187
by juergen.scholl
The easiest way is a capable scantool which can read the information from the skim module (immo unit) and/or pcm, another is reading the eeproms of these modules directly. If you're not familiar with these procedures or lack the tools your best bet is a locksmith.
- juergen.scholl
5 years 5 days ago - 5 years 5 days ago #52188
by juergen.scholl
You also could swap the chip from the old to the new module ....
Last edit: 5 years 5 days ago by juergen.scholl.
