Cam timing causing a P0420?
  • Chad's Avatar Topic Author
5 years 6 days ago - 4 years 11 months ago #52172 by Chad
I have a 2012 Chrysler 300 3.6L. Customer complaint is CEL and a fuel smell during acceleration. Only codes are P0420 and P0128. This car came from a local muffler/brake shop. New Catalytic converters were installed "about a year ago". Could a Cam/Crank variance of 4° to 5° (4° by pids, up to 5° by waveform) cause an extremely rich condition, on one bank, during heavy accel?
3 out of 4 cam/crank difference/variation pids show -3° to -4°, at idle. Bank 2 exhaust is close to 0°. All cams seem to phase, as they should during a test drive. I observed the Bank 1 Upstream sensor hanging around 750mv to 850mv, at idle. It looks like it is trying to switch, but is stuck in the RICH range.
Bank 1 Yellow is Upstream. Red is Downstream.
The Bank 1 Downstream sensor will begin to cycle like you would expect the upstream sensor to cycle, while the Upstream sensor is stuck RICH. I checked and the connectors are not reversed. Inducing a vacuum leak drives the sensor lean, momentarily. I called the Upstream sensor "lazy" and shotgunned a new sensor at it. No difference (re-installed old sensor). I stuck a pulse sensor in the tail-pipe and intake. I can see a distinct Bank-to-Bank issue in the exhaust waveform.
I compared Cams and Crank to a Known Good. They match up pretty well, I think. Only a few degrees of differences. I have seen worse. RC looks good, in my opinion. This vehicle runs great, with the exception of the fuel smell during accel and poor fuel mileage. No chain slap/rattle noise. I would recommend new chains, just based off of mileage (157,000) but, I want to be sure I get to the bottom of the P0420. Exhaust back pressure is 1 1/2 psi @ 3000 rpm.
Last edit: 4 years 11 months ago by Chad.
5 years 6 days ago - 5 years 6 days ago #52178 by juergen.scholl
Replied by juergen.scholl on topic Cam timing causing a P0420?
Chad,
I don't think a 4 or 5 degree deviation on cam timing is possibly the root cause of the P0420.
From your description I understand that the upstream sensor on bank one is reporting a truly rich condition. The O2 sensor detects the condition, nevertheles at higher rpm/loads the pcm isn't in fuel control anymore.
While running "a year or so" with this issue the replacement cat got damaged. Do you know why the previous converter(s) was changed, same reason? The underlying cause was rich running and was left unaddressed so it repeated itself?
If the scan/scope data shows similar injection on times for both banks you may want to compare the pressure drop of the injectors from bank 1 to bank 2 or switch them bankwise. They may have different flow rates.
Your pressure pulse reading seems to be taken cranking, do you observe the same difference in exhaust pulses at idle as well? Could the design of the exhaust system contribute to the bank to bank difference?
Last edit: 5 years 6 days ago by juergen.scholl. Reason: I was in the logic tunnel and wrote idle instead of cranking, refering to the exhaust pulses
5 years 6 days ago - 5 years 6 days ago #52182 by Chad
Replied by Chad on topic Cam timing causing a P0420?
I don't think a 4 or 5 degree deviation on cam timing is possibly the root cause of you the P0420.
I wouldn't, normally, think so either. But everything else looks good, with the exception of the B1S1. I am struggling with the "Chiken? Or, the egg?", on that. Is that the cause? Or, the effect of a bad CAT? Lack of exhaust back-pressure makes me think it is the Chicken.
I'm not sure what the history is. I will call and interrogate the muffler shop, tomorrow.  I got the impression that the currently installed Cats may be the second set that the muffler shop has installed. I'm not sure. They told me that they had talked to the manufacturer. The manufacturer refused to warranty, saying that there must be an underlying issue. This makes me think that these Cats are the second replacements. I will get the full scoop on this, tomorrow.
I may do this, tomorrow. I haven't pursued this avenue because fuel trims at idle look good.
Your pressure pulse reading seems to be taken at idle, do you observe the same difference in exhaust pulses at idle as well? Could the design of the exhaust system contribute to the bank to bank difference?
The exhaust waveform was engine Cranking. Not, running.  I haven't looked at them with the engine running. I'll add that to "the list". The two exhaust banks "Y" together, into one pipe. Then the one pipe splits, and "Y"s back into two tail pipes.  All in a, relatively, straight line. The capture was taken from one tail-pipe, with a wet rag stuffed into the other tail pipe. I will play around, and re-test this, tomorrow. I think I may even pull the the Upstream O2 sensors and capture exhaust pulses from the bung holes.
Last edit: 5 years 6 days ago by Chad.
5 years 6 days ago #52185 by Cheryl
Replied by Cheryl on topic Cam timing causing a P0420?
Get a o2 simulator for downstream o2. You’ll never have a 420 again. But In all seriousness any tsb? Relating to any flash updates? Have you checked actual o2 sensor voltage to make sure pcm isn’t lying to you? Bet Juergen is right about the injectors
5 years 3 days ago #52219 by Tyler
Replied by Tyler on topic Cam timing causing a P0420?
When I see CDJR O2's behaving the way yours are, I immediately suspect an exhaust leak and/or a malfunctioning downstream O2 sensor.
Do you know what the O2 Goal (0-1) (V) PIDs are reading on the manufacturer side? I suspect they're part of the downstream fuel control strategy. A large difference bank-to-bank might suggest an exhaust leak OR a cat that just isn't storing oxygen the way it should.
5 years 3 days ago - 5 years 3 days ago #52221 by Chad
Good timing, Tyler. I was just about to cut the cat out, to eliminate it from the equation. Good call, too. I had not paid any attention to the Goal pid.
B1S1 goal is .750
B2S1 goal is .570
So...now, I need educated. Why would the Bank 1 goal be .750?
I know that the cat is bad. I have been tasked, by the muffler shop, to determine the cause of the failure. They just installed them (aftermarket), earlier this year in March.
The manufacturer is refusing to warranty, claiming there must be an underlying issue. At this point, I feel like I am chasing a ghost.  I am going to cut the cat out, and re-look at the exhaust waveforms. If the Bank-to-bank anomaly goes away with the Cat, I have to conclude that the Cat should be warrantied. The muffler shop will "eat it".
Last edit: 5 years 3 days ago by Chad.
5 years 3 days ago #52224 by Tyler
B1S1 goal is .750
B2S1 goal is .570
Yeah, me too. :silly: I nearly got my ass kicked by a Chrysler 300 about a year ago, and I've been watching O2 Goal on known good cars ever since. No training material or service info that I've found talks about it's usage. Just me making it up as I go.
From that '13 T+C I uploaded:
O2 Goal starts trending up around frame 200 when the downstream goes low, and the Short Term reacts around the same time. So, if your O2 Goal on B1 is high, then I'd say the PCM isn't happy with the downstream O2 behavior. Which makes sense - it's switching when it should be steady above .6-.7V. Meanwhile, the upstream O2 is trending rich. I'm surprised it hasn't set an O2 slow response code yet. :huh:
Aftermarket. Play stupid games, win stupid prizes.   As usual, as long as it's not misfiring or drinking fluids (oil/coolant/fuel), then it's done IMO.
5 years 2 days ago #52243 by juergen.scholl
As mentioned  in the video chat the domestic vehicle pids list offers some information on the goal O2 parameter.
The following user(s) said Thank You: Tyler, Chad
4 years 11 months ago - 4 years 11 months ago #52333 by Chad
After finding nothing wrong, I cut the Cat out. The catalyst was clean and pristine. However, It was broken, not melted. There were no signs of damage, on the outside. The Cat has two sections of catalyst with the downstream O2 sensor installed in between. The upstream section of catalyst was broken. The dust from the broken upstream section was, partially, restricting the downstream section. I was surprised by this because of the Exhaust Back Pressure test. Holding at 3000 RPM, back back pressure was only 1.5 psi.  I will note that I would see it spike up to 5-7 psi, for just a fraction of a second, before it steadied at 1.5 psi. The spike was so brief that you could miss it, if you blinked. I didn't think much of it, until now. I called the muffler shop with my conclusion. They said that they would replace the Cat.  They later called me and said that they had, again, talked to the manufacturer. The manufacturer has decided to warranty the Cat. (This was the FIRST replacement Cat, installed earlier this year in March. I had speculated that it might be a second replacement, but I was wrong.)
For anyone interested, here is a follow-up on the exhaust waveforms. First is waveform with a pulse sensor in each upstream bung hole, and one in the tail pipe.
Bank 1 (slightly restricted)      Bank 2
Here is a Bank 1  offset, and over-layed atop Bank 2.
The following user(s) said Thank You: Tyler, juergen.scholl
4 years 11 months ago #52334 by juergen.scholl
Thank you for the update Chad.
Just to make sure I understand this correctly:
The exhaust pressure waveforms were taken with the damaged cat still in place and during cranking, at around 700 ms for the complete cycle, right?
I'd call this a VERY tough one and wouldn't dare to point at the catalytic converter just based on the back pressure waveforms...
Is there any chance you can get exhaust pressure readings once the new converter is in place? (I know, most probably not...)
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 11 months ago #52336 by VegasJAK
Replied by VegasJAK on topic Cam timing causing a P0420?
I had called this a bad cat to myself from the beginning. Paul has been firm on back pressure above 1psi @ 3k RPM being a good indicator of a restricted exhaust.. With 1.5 back pressure, an 02 stuck rich, an oscillating S2 and a P0420, I would have concentrated on the rich 02 and oscillating S2. They both told me that was the possible cause of the cat failure, the 1.5 back pressure and P0420. The oscillating S2 is what caught my attention first.
Agree fully with Paul that low tech is still a viable way to diagnose. It so easy to misinterpret waveforms.
Please let me know if my thinking is off. We learn by our mistakes and God knows I have made a lot of them in my life time.
4 years 11 months ago #52337 by Chad
It was never a question of IF, or IS the cat bad.  That has been known from the beginning. The question was "Is there an underlying issue that CAUSED the cat to fail?"
4 years 11 months ago #52338 by Chad
Yes. Those waveforms were while cranking, with the bad cat, still, installed.
I asked the owner to bring it back, after the new cat has been installed, so that I could look at some "AFTER" data, pro bono. He said he would. I hope he does.
  • VegasJAK
  • VegasJAK's Avatar
4 years 11 months ago #52339 by VegasJAK
With what Chad had to work with all roads would lead him to the cat. If he had fixed the true rich condition he still would have a P0420 as the cat was/is defective, right?
Juergen points out a cause as a true rich condition which would have lead to the original cat going bad. But, Chad was tasked with why the new cat failed. It's failure had nothing to do with the true rich condition as the cat was found to be defective. Two distinct problems. So we're back to what is the true rich condition. I have to admit Tyler lost me on the 02 goal readings.
4 years 11 months ago - 4 years 11 months ago #52341 by Chad
I'm not sure but, It is my understanding/belief that the rich condition/Goal of .750  was caused by the down stream O2 sensor cycling lean, due to the bad cat?   A Downstream fueling strategy? If/When the owner brings it back, I will update.
4 years 11 months ago #52345 by Noah
Replied by Noah on topic Cam timing causing a P0420?
Good find with the broken catalyst Chad, way to get down to it! I honestly didn't envy you for landing that task.
Did you happen to observe if the upstream O2 activity returned to normal after the new cat? I definitely would have called a lazy o2 early on.
The 5-ish degrees of timing definitely threw a variable into the mix also.
4 years 11 months ago #52351 by Tyler
...with a pulse sensor in each upstream bung hole...
Sorry not sorry. :silly:
But seriously, well done on making the call! It's never easy being the third (or fourth?) party trying to sort out a mess.
That's my understanding, anyway. :silly: I think O2 Goal represents the PCM's modification of the fuel calculation to make the downstream O2 behave correctly. Values above .45V represent adding fuel, less represents subtracting. I could be off about the .45V value? But that's what I usually see. Why didn't they just call it 'downstream fuel control' or 'post-catalyst fuel trim'? Because Chrysler, that's why. ;)
IMO, part of the issue is that the PCM *assumes* a working catalyst when making changes to O2 Goal. Evidently, even when a P0420 is set, the PCM will still crank up O2 Goal to get what it wants.
Time to create page: 0.438 seconds
