No crank no start problem
- autojoe
- Thank you received: 7
- Desmond6004
Check the battery voltage when the starter engages, most cars drop to 10v while cranking. That voltage will tell you whether the starter is actually loading up or not. Then if you load test your battery down to 10v it will show how many amps it takes to draw the battery down to 10v which would give an indication of how many amps your starter was drawing. You could also try doing your starter test with cables when it is on the vehicle, feed the solenoid terminal and make it pull in, that will bypass anything on the vehicle that could e interfering with it and show you whether the fault is at the starter or somewhere on the cut-out alcohol system.
Was this observed on a scope, or on a DMM? Do you happen to have the scope capture available to post?When I was testing amperage draw key in start position the amps was bouncing all over the place. I appreciate any help you can give me on this matter.
Fluctuating current during a no crank suggests to me that you were possibly looking at an open or high resistance in the starter motor itself. Either worn brushes or a bad commutator segment. Both will allow the solenoid to engage, but won't allow the motor to turn. The current jumping around is caused by arcing across the resistive connection.
By removing the starter, you may have temporarily fixed the problem. :silly: Kinda like tapping on the motor with a pry bar with the key in crank. If you're confident that there's no voltage drop across the starter B+/block ground, and that the engine turns with a wrench, then I'd say it's starter time.
- autojoe
- autojoe
- autojoe
I'm not sure? I've never been much for bench testing starters and alternators, TBH. Too many variables between what the 'tester' actually tests for, and whoever is running the tester.Would starter tester at AZ expose a weak starter motor?
- autojoe
That's what I was thinking, probably not a bad idea to put a big ratchet on the crank pulley and make sure the engine turns. I have seen locked up alternators, AC compressors and power steering pumps all stop an engine from cranking as well. So if it doesn't turn by hand, take the belt(s) off and try it.Can't do voltage drop wiring and everything buried. Used to use carbon pile to check amperage draw but I got rid of mine along time ago. I now have midtronics exp 1000. Probably going to reinstall and see if problem still exists. Maybe see if engine seized. Thanks.
- autojoe
- autojoe
In a nutshell,...what Tyler said.If you're confident that there's no voltage drop across the starter B+/block ground, and that the engine turns with a wrench, then I'd say it's starter time.
Since there is an access problem to the BAT+ wire at the Starter when it is installed, while the starter is removed I would suggest to use a battery-load tester connected between the disconnected starter BAT+ cable and the engine block to do your voltage drop test. This should test the Starter cable and the engine block ground at the same time.
- autojoe
