2000 ranger 3.0 manual transmission
- Cheryl
- Thank you received: 215
5 years 1 week ago #52038
by Cheryl
2000 ranger 3.0 manual transmission was created by Cheryl
Does anyone have torque spec for the cylinder heads? And order to torque them
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 1 week ago #52039
by juergen.scholl
Replied by juergen.scholl on topic 2000 ranger 3.0 manual transmission
- juergen.scholl
5 years 1 week ago - 5 years 1 week ago #52040
by juergen.scholl
There is an error in the FSM, step one should read 80 Nm instead of 50 and step three 55 Nm. Number 4 and number 6 seem o be inverted as well, for the tightening sequence you may better refer to the second picture.
Last edit: 5 years 1 week ago by juergen.scholl.
5 years 1 week ago #52044
Replied by Tyler on topic 2000 ranger 3.0 manual transmission
- Matt T
- Thank you received: 276
5 years 1 week ago #52049
by Matt T
Replied by Matt T on topic 2000 ranger 3.0 manual transmission
There is obviously something wrong with the torque figures. Nm should be higher than ft lb not lower. Tightening sequence also looks suspect.How'd you find that, Juergen?
5 years 1 week ago #52050
Right, I got that. :silly: I was more interested in knowing the sources for both specifications. As in, was one from Mitchell, another from AllData?There is obviously something wrong with the torque figures. Nm should be higher than ft lb not lower. Tightening sequence also looks suspect.
- Cheryl
5 years 1 week ago #52151
by Cheryl
Replied by Cheryl on topic 2000 ranger 3.0 manual transmission
Question about the cam synchronizer I have the alignment tool engine set on tdc compression stroke. Does the housing have to be in a certain spot as long as the connector is plugging in without it pulling on the connector pigtail? It’s the last thing we have to do before we fire it up
- juergen.scholl
5 years 1 week ago #52156
by juergen.scholl
- Cheryl
5 years 6 days ago #52170
by Cheryl
Wonder if the 38 degrees is critical because I’m looking online people are saying it’s more of a position so the wiring harness isn’t pulled tight
Time to create page: 0.346 seconds
