FIXED 2008 Nissan sentry 2.0
- benz42dude23
5 years 2 weeks ago #51899
by benz42dude23
2008 Nissan sentry 2.0 was created by benz42dude23
I'm working on a 2008 Nissan sentry 2.0. Fellow employee called an engine computer for a crank no start issue. Started the diagnosis over confimed I have no spark or injector pulse. Both cam and crank sensor have been replaced. What is stumping me is I have 5 volts on the green yellow and blk red wire of the camshaft postion sensor also the green red and yellow wire on the crankshaft portion have 5 volts on them. I feel I'm missing something simple to get this car running. I don't feel both wires should have 5 volts on them. I can communicate with every module so I feel it's not a dropped 5 volt. Starting to move more towards the diagnosis side of the shop and this one really kicking my butt.
- Mariowinax1
5 years 2 weeks ago #51902
by Mariowinax1
Replied by Mariowinax1 on topic Re:2008 Nissan sentry 2.0
What trouble code is it throwing ??
Have the same car
Sent from my SM-A217F using Tapatalk
Have the same car
- benz42dude23
5 years 2 weeks ago #51904
by benz42dude23
Replied by benz42dude23 on topic Re:2008 Nissan sentry 2.0
Currently no codes since ecm replacement and rewriting Vin and progring keys.
- Mariowinax1
5 years 2 weeks ago #51905
by Mariowinax1
Replied by Mariowinax1 on topic Re:Re:2008 Nissan sentry 2.0
Find a different programming tool and reprogram the keys to the new ecu. It should start.
ID mismatch to the ECU and body control will let car crank but won't start, when ecm is programmed correctly it will start right up.
Hope the new ecu you are replacing part number is the same as the old one ?
- benz42dude23
5 years 2 weeks ago #51922
by benz42dude23
Replied by benz42dude23 on topic 2008 Nissan sentry 2.0
Fixed. Found that it was a faulty aftermarket crank sensor that was put in before computer replacement and fouled spark plugs. Thank you for your help.
