2008 Chevy Tahoe 4.8l
  • JROB27
  • JROB27's Avatar Topic Author
5 years 3 weeks ago #51874 by JROB27
2008 Chevy Tahoe 4.8l was created by JROB27
Hey guys, I have a 2008 chevy tahoe 4.8l giving me a P023f code. I checked for power and grounds at the fuel pump flow module and power coming from ECM for fuel pump "relay" inside of the Module. All battery voltage. The 2 wires going to the fuel pump from the module though I'm getting no voltage on either side. It is a ground-switched fuel pump so I should be getting 12v on both sides right? and it should drop to 0v when primed and cranking?
5 years 3 weeks ago #51875 by Cheryl
Replied by Cheryl on topic 2008 Chevy Tahoe 4.8l
Load the circuit put a test light between those two wires. Crank it should light. If not module is done. If you checked all that already
