Crank/no start when hot
  • bobbyc9055
  • bobbyc9055's Avatar Topic Author
5 years 3 weeks ago #51748 by bobbyc9055
Crank/no start when hot was created by bobbyc9055
Starts no problem when cold, and runs great for hours. Shut off and try to start, cranks but no start. has fuel pressure, spray starting fuel in intake, nothing. has no spark off of coil! Hope you can help. didn't what to go and buy a PCM yet!
  • bobbyc9055
5 years 3 weeks ago #51751 by bobbyc9055
Replied by bobbyc9055 on topic Crank/no start when hot
5.0 1998 Jeep Grand Cherokee, pressure will cranking.
5 years 3 weeks ago #51752 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Crank/no start when hot
Istr these need both cam & crank position signals to start but once running use only the crank so cam sensor droppinh out due to hear soak where to start looking.
5 years 3 weeks ago #51757 by Cheryl
Replied by Cheryl on topic Crank/no start when hot
When did they make a 5.0 liter keep? I know the 4.0 3.7 4.7 and the 318
  • bobbyc9055
5 years 3 weeks ago #51758 by bobbyc9055
This looks like the issue, Thanks. Would it have no spark if the cam sensor was faulty?
  • bobbyc9055
5 years 3 weeks ago #51760 by bobbyc9055
I will let you know. Thanks
  • bobbyc9055
5 years 2 weeks ago #51932 by bobbyc9055
last few days have been cool in northern IL, so jeep has been running fine. Finally stopped starting again to test cam sensor. This is what I got:
-5v at supply w/ignition on
-5v at signal w/ignition on
-have 12v at ground when ground to + on battery
-have continuity on ground w/ignition on
-no continuity on ground w/ignition off
This is a cam sensor located in the distributor.
I'm bad, it is a 5.2 liter :)
  • bobbyc9055
5 years 2 weeks ago #51945 by bobbyc9055
  • bobbyc9055
5 years 2 weeks ago #51946 by bobbyc9055
Don"t know if this went through earlier, didn't see it in the Forum.
