turns over but wont start
  • curtizmo
  • curtizmo's Avatar Topic Author
5 years 3 weeks ago #51736 by curtizmo
turns over but wont start was created by curtizmo
2002 sequoia 4.7  replaced feul pump and feul filter. spray starting fluid and it will start also replaced feul pump relay no hrlp code c1234 and c1203  diiagnostic check
5 years 3 weeks ago #51744 by Cheryl
Replied by Cheryl on topic turns over but wont start
First do have any fuel pressure? Second is there any immobilizer lights on in the dashboard?
5 years 3 weeks ago #51746 by juergen.scholl
Replied by juergen.scholl on topic turns over but wont start
IF the engine keeps running after starting on external fuel and you have a scantool look for the throttle position sensor. It may be at fault indicating clear flood. Otherwise more info will be needed.
5 years 3 weeks ago #51753 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic turns over but wont start
Low fuel pressure is the prime  (!)  suspect. Injection engines need max fuel pressure at cranking.  Note *PRESSURE*  a simple  check for fuel won't tell you anything useful.
