[FIXED] p0401
- kman200
- Ben
- Thank you received: 215
- kman200
- Ben
- kman200
- Ben
Were you observing the DPFE voltage at the sensor directly, or on scan data? Just wondering about wiring integrity from the sensor to the PCM, as an excessive resistance problem could account for that.
Could you do some voltage checks at the DPFE sensor? I'd like to know what voltages you see on all three wires, plugged in and unplugged. That'll let us know quickly if there's a wiring problem or not, and what the next step is.
- SniperDan
- Thank you received: 28
~W. Edwards Deming
- kman200
- Nandor69
- Thank you received: 5
kman200 wrote: I haven't checked the vaccum reservoir yet it's been to cold. I did measure the the 3 wires with a voltmeter. Signal wire was 1.1 connected 5.4 disconnected. Ground wire was 0 both ways and the the other wire was 5.3 both ways. Something else that I noticed was when I put vaccum on the small side of dpfe port the voltage goes up on the signal wire.
Sweet, thanks! Like Nandor69 said, that indicates good wiring.
Seeing higher voltage with vacuum on the small port... How far does the voltage go up? And how much vacuum are you applying? Not trying to grill you!
- Ben
- kman200
- kman200
kman200 wrote: Today I decided to try my old egr tube since it had been broken long before I had this problem . I stuck it on and checked the voltage at the dpfe sensor and the volts went up over 4. I thought I must have bought a bad tube so I went and got another one . I put it on but still the volts never went up. The only difference between my old one and the new ones is the orifice shape. I ended up welding the bottom half of the new one to my old one. Seems to be working good.
What tha... :huh: I don't suppose you could get pictures of this for me? Just interested to see the difference.
When you mentioned being able to put vacuum to the DPFE and getting a signal change, that's when I started thinking about something wrong with the tube and hoses. You'd said the hoses were clear, and I (mistakenly) figured your new EGR pipe had to be good! :lol: I know better than to assume 'new' means 'working correctly'.
Just thinking out loud here... If the orifice was larger on the new tube, then the difference between the two DPFE ports wouldn't be as large, and thus the DPFE sensor wouldn't show the correct signal during EGR operation. Am I thinking about this correctly?
- kman200
kman200 wrote: i1376.photobucket.com/albums/ah33/kman20...1936_zpsebzn9log.jpg Both are made by Dorman for my truck.
I KNEW IT. :lol: :lol: Dorman is so hit and miss, it's super frustrating.
I don't know about the orfice size but that does make sense. That was the first thing I changed when I got the p0401 . I think the original problem was clogged ports on the throttle body which was the second thing I fixed.
Agreed. Really sucks when the parts let you down.
I'm gonna slap a [FIXED] on this one.
