98 chrysler sebring runs fine then dies no codes
  • Mort
  • Mort's Avatar Topic Author
5 years 1 month ago #51494 by Mort
Working on a 98 chrysler sebring 2.5 it was throwing a PO340 code I replaced the cam sensor/distributor it runs fine for about 5 minutes then dies. it is not throwing any codes the fuel pump / fuel regulator has been replaced.  I am not understanding why it is doing what it is doing. has anyone come across this situation before?  if so how do I correct this issue?
5 years 1 month ago #51495 by Ben
Does it restart immediately? If so how long before it dies again? Can you access scan data or codes only?
  • Mort
5 years 1 month ago #51497 by Mort
No does not restart immediatley. codes only. I dont have a program for data
serems to have plenty of fuel 50psi. I would think if it was an injector issue it would show a misfire code.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
5 years 1 month ago #51506 by VegasJAK
Check the cam and crank signals. These are known to throw cam codes when its the crank sensor.
Hope this helps.
  • Mort
5 years 1 month ago #51519 by Mort
I'll give it a shot thanks
  • Mort
5 years 1 month ago #51523 by Mort
I have crank and cam signal voltage. started the car it ran for around 3 minutes and died, pulled off the fuel line at the rail and nothing came out.   I jacked up the rear of the car and put it on jackstands  and it starts and runs.  I am thinking it is sucking air from somewhere or the fuel pick-up  is in a bind or the fuel filter is the culprit
