looking for wiring diagram for Honda CRV 2008 pcm wiring diagram
  • sam1133
  • sam1133's Avatar Topic Author
5 years 1 month ago #51464 by sam1133
Hi all,
I would like have wiring diagram for Honda crv PCM, as i got a code p2085 and p0507, i checked ect 2 there is no 5 voltage reference at the connecter, i would like to check if the pcm is commanding 5 volts reference to the ect 2..
5 years 1 month ago #51466 by Noah
Connector A, pin #34, green
  • sam1133
5 years 1 month ago #51468 by sam1133
Do you have the wiring diagram for all the circuit from the pcm to all the sensors and connections connected to 5 voltage reference circuit...
5 years 1 month ago - 5 years 1 month ago #51472 by jreardon
You mean P2185? ECT sensor 2 circuit high voltage? First unplug ect and check for 5 volts, plug it in, if it's still 5v, you have no ground.
Sorry, lol, I just read your post again. One moment while I pull it up.
Last edit: 5 years 1 month ago by jreardon.
5 years 1 month ago - 5 years 1 month ago #51473 by jreardon
Also that wire's a dedicated line, it doesn't share it with other 5v reference circuits. Diagram is just going to be a line, lol, which doesn't tell you anything besides it going to pin #34.
  • sam1133
5 years 1 month ago #51490 by sam1133
I have no volts at all.. 0 volts.. Is it 5 volts all the time
  • sam1133
5 years 1 month ago #51491 by sam1133
Can you exactly locate this connector A connector and pin 34, I found one, but it is the right side of the transmission, under the hood..
  • sam1133
5 years 1 month ago #51492 by sam1133
Also does matter if the transmission wiring is disconnected now, will the 5 volts be there in ect 2 connector, green wire..
5 years 1 month ago #51496 by jreardon
Take a reading with key on, backprobed at this green wire at the PCM. If you have 5 volts at the computer but zero at the sensor, then you have an open.
In identifix, the connector is pin 33, not pin 34, so that would mean I'm looking at Latin America model? dunno. Sam, which connector do you have?
imgur.com/a/v3Erb6D
  • sam1133
5 years 1 month ago #51498 by sam1133
Pcm is in the glove box? Vehicle is north America..
5 years 1 month ago #51499 by jreardon
Left side of Engine Compartment. I have NA version selected in identifix and it's giving me, according to Noah's picture, the Latin America pinout for some reason (both OE and colored diagrams). I don't know why lol. Check and see which connector you have, to settle this error once and for all.
Time to create page: 0.383 seconds
