jeep p0344 code
- ronald316
- Thank you received: 13
5 years 1 month ago #51345
by ronald316
jeep p0344 code was created by ronald316
hi everyone i have a 2006 jeep wrangler 4.0 259000 k.m it has code p0344 cam sensor the customer replaced the cam sensor .when it came in i did a cam and crank sync took for a test drive the code cam back i checked my powers and grounds loaded them and found bad gound wire at crank sensor.i repaired the ground dark blue with green trace.now its worst i use to be able to drive it 3 to 4 k.m before the light would come on now i don t even make it of the parking lot
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
5 years 1 month ago #51348
by VegasJAK
Replied by VegasJAK on topic jeep p0344 code
Check crank sensor. Chrysler is notorious for cam codes when it's a crank sensor.
5 years 1 month ago #51350
Replied by Tyler on topic jeep p0344 code
Agreed. This would not be the first time a CDJR crank sensor sent someone for a loop.
Can you monitor the cam and crank signals while going for a drive in the parking lot? You'd be able to see if the signal line is going high/low/out of sync/whatever. That'd narrow your list of suspects.
Was there any other related harnesses that you disturbed while doing the wiring repair?
- VegasJAK
5 years 1 month ago #51351
by VegasJAK
Are you sure about the dark blue/ green wire being ground? Should be black/light blue for ground. Orange for 5v ref and gray/black for signal.
- ronald316
5 years 1 month ago #51354
by ronald316
Replied by ronald316 on topic jeep p0344 code
i will recheck the diagram again
- ronald316
5 years 1 month ago #51391
by ronald316
ok i just checked on identafix cam 5v yel/pimk cmp sig dkblu/gry sens gnd dk blue/dk grn crankshaft sens gnd dkblu/ dk grn ckp sig brn/lt blu 5volt pink/yel
- ronald316
5 years 1 month ago #51392
by ronald316
i don t think i did but i will check thanks
