Re:05 hyundai sonata odd code issues.
  • ba109296
  • ba109296's Avatar Topic Author
5 years 1 month ago #51219 by ba109296
05 hyundai sonata odd code issues. was created by ba109296
05 sonata 2.4 autoCheck engine light will pop only at WOT and after a shift. Once you let off the pedal it will sometimes go away. I did a video of what pops up in the pending codes on my snap on scanner.recent timing belt, water pump, plugsI have tried 3 different sets of ignition coils. The codes don't always stay the same. Compression is good. Called hyundai and there are no recalls.
5 years 1 month ago #51221 by Ben
Replied by Ben on topic Re:05 hyundai sonata odd code issues.
Well 1 at a time it has a problem with what it's seeing from the TPS, enter live data and graph the TPS voltage KOEO slowly apply the accelerator pedal to WOT and see if there's any glitches in the voltage (typically less than 1 volt to over 4 volts (you can also graph TPS %) the exact % isn't important if it makes it to 98 % close enough your looking for glitches in the signal or only making it to 60% or something like that. the misfire may be related to the injector circuit code, I would start with TPS first
  • ba109296
5 years 1 month ago #51222 by ba109296
Replied by ba109296 on topic Re:05 hyundai sonata odd code issues.
Tps showed a fault a few weeks ago and was replaced with an oem unit.
at that time I tested it.
I'm not sure if these are actual good codes based on how they are just randomly cycling.
5 years 1 month ago #51224 by Tyler
Replied by Tyler on topic Re:05 hyundai sonata odd code issues.
What codes do you get in Global OBD? If Global doesn't have the same goofy behavior, I'd rely on it instead of the OEM codes.
5 years 1 month ago #51231 by Cheryl
Replied by Cheryl on topic Re:05 hyundai sonata odd code issues.
Does it feel like a misfire?? Current clamp the injectors if you have a scope.
  • ba109296
5 years 1 month ago #51232 by ba109296
I will look tomorrow.
  • ba109296
5 years 1 month ago #51233 by ba109296
When the light pops on it definitely kills power and acts like its a missfire. Then light goes away and all is good again. Until it does it again.
5 years 1 month ago #51234 by Cheryl
I’d definitely hook up the scope to the injectors. One channel around the control wires and one backprobing the#3 injector
Time to create page: 0.355 seconds
