Re:2003 ford excursion 6.0 diesel
- BRAD70
5 years 1 month ago #51169
by BRAD70
2003 ford excursion 6.0 diesel was created by BRAD70
Hello Crank no start. my testing is leading me to high pressure oil pump. but before removing intake and buying fittings to test. i noticed no rpm when cranking. should i have rpm when cranking??? Thanks in advance
- Hardtopdr2
- Thank you received: 150
5 years 1 month ago #51184
by Hardtopdr2
Replied by Hardtopdr2 on topic 2003 ford excursion 6.0 diesel
Yes you should have rpm signal from cam and crank sensors.
The following user(s) said Thank You: BRAD70
5 years 1 month ago #51186
Replied by Tyler on topic 2003 ford excursion 6.0 diesel
Should definitely have RPM signal on the scan tool while cranking. I'd expect 150 RPM or more with charged batteries. What's the IPC actual and desired, and the IPR during cranking?
- Ben
- Thank you received: 215
5 years 1 month ago #51195
by Ben
Replied by Ben on topic Re:2003 ford excursion 6.0 diesel
Slow down on hp oil pump if it doesn't have 500psi oil pressure (required to start) its not likely the hp pump (it will show up at high loads way sooner than no start) more likely is a stuck ICR , a large high pressure oil leak , or a misreading ICP sensor if it does have oil pressure and is a no start that either a bad FICM (check injector voltage(needs 48v)) or a cam crank sync issue (check FICM Sync Pid (should say yes while cranking))
- washer
- Thank you received: 13
4 years 7 months ago #54800
by washer
Replied by washer on topic Re:2003 ford excursion 6.0 diesel
Just wondering what ever became of issue. I'm interested.
- BRAD70
4 years 7 months ago #54835
by BRAD70
Replied by BRAD70 on topic Re:2003 ford excursion 6.0 diesel
ENDED UP having a cracked/split steel line on the high pressure fuel pump under the intake manifold. It was a crank no start.
- washer
4 years 7 months ago - 4 years 7 months ago #54851
by washer
The STC (snap to connect) I assume. Yep, those ALL fail.
Lol, after I hit submit, I noticed this was a 2003. I assume that had the aluminum HPOP. I've never actually had one of those apart, so, ignore my comment about STC.
Last edit: 4 years 7 months ago by washer.
- BRAD70
4 years 7 months ago #54861
by BRAD70
No worries. I was sure the high pressure pump was out. when found the cracked line.
