Ford Explorer 2014 No crank
  • Isaacs_motoring
  • Isaacs_motoring's Avatar Topic Author
5 years 1 month ago #51050 by Isaacs_motoring
Replied by Isaacs_motoring on topic Ford Explorer 2014 No crank
Appreciate you, pretty much, my friend.
5 years 1 month ago #51051 by jreardon
Replied by jreardon on topic Ford Explorer 2014 No crank
I only ordered it B E T cause it's listed alphabetically in the connector list, so again, crossing fingers :)
  • Isaacs_motoring
5 years 1 month ago #51052 by Isaacs_motoring
It looks spot on, as I compared with the diagram I have and pins 7 and 37 are the ones I'm after, also has the same color code.
5 years 1 month ago #51053 by jreardon
Now do an ohm check across them, relay in and relay out should give different results.
  • Isaacs_motoring
5 years 1 month ago #51055 by Isaacs_motoring
Would do that, I also intend to see if I have the power on the green and white wire right out of the computer.
  • Isaacs_motoring
5 years 1 month ago #51079 by Isaacs_motoring
Hey my friend (jreardon) could you please hook me up with the main powers and ground for the pcm. Appreciate it.
5 years 1 month ago #51080 by jreardon
Seems like powers and grounds are all on the B connector.
File Attachment:
File Name: powersandgrounds.pdf
File Size:361 KB
File Attachment:
File Name: b.pdf
File Size:292 KB
  • Isaacs_motoring
5 years 1 month ago #51081 by Isaacs_motoring
Thanks
  • Isaacs_motoring
5 years 1 month ago #51259 by Isaacs_motoring
Hey guys, quick update on the job. We got a new pcm, programmed and bam, car cranked and starts once. Appreciate you all for your help
