EMC/IGN
  • montesick2021
  • montesick2021's Avatar Topic Author
5 years 2 months ago #50862 by montesick2021
EMC/IGN was created by montesick2021
Thanks for the reply guafa. I had the ICM checked and it checked out good. I the decided to do a test light probe on all of the fuses in the electrical fuse box #1 under the hood. When I probe the ecm/ign fuse it showed that it was fine with the test light with the ignition  on. It says on the wiring  diagram that it is supposed to be hot in the run or start position. I decided to check the the fuse ports itself on all of the fuses that show hot in the run or start position one at a time. On all of those fuse ports with the ignition on, one lead would read hot the other lead would not. When I got to the icm/ign port both leads are hot. One lead lights the test light normally but on the other lead the test light is only half as bright.Is this a sign of a bleed over? In the wiring diagram it shows one pink wire going to the ecm but there are two pink wires going to that fuse port. The small pink wire does go to the ecm from  one lead in the port. There is a bigger pink wire coming out of the other lead. It looks like that is the the wire that has the bleed over. Can anyone tell me what that wire goes to? Thank you for your help.
Time to create page: 0.261 seconds
