very intermittent lack of power. Like 5 seconds a day. Does anyone know if the fuel pumps are an issue on these? Or the driver modules? It’s hard to catch. The short blip of fuel pressure drop is all I seen in 2 days. Could a bad fuel pressure sensor cause driveability symptoms with no codes can’t add image but pressure for the low side goes down to 19.5psi and high side actual is 7 mpa desired was 12 mpa
Last edit: 5 years 2 months ago by Cheryl. Reason: Adding pic
