2011 BUICK LACROSSE CXS FWD , 3.6 engine NO CRANK , NO START !!!
  • Rickyrick
  • Rickyrick's Avatar Topic Author
5 years 2 months ago - 5 years 2 months ago #50413 by Rickyrick
PAUL ,,,,,my nightmare started sept 2020 .........PO23F AND UO100 , on code reader , but screen in car says ,stabili trak and side detection problems  lol ... here is problem ,it started with ride to dr's office .after about 3 hrs approached the car and when i opened the door ,it made a very fast clicking sound under the hood . i got in push the start button ,nothing ,no crank ,no start . the clicking sound comes on when i disconnect and reconnect the battery ,open the door ,trunk or hit the power locks . upon investigation ,my # 10 ecm fuse continues to burn with the # 7 relay being left in .when i remove the relay ,the # 10 ECM fuse doesnt blow anymore and the clicking stops . the suspect relay is KR75 , IT IS LABELED AS RELAY # 7 ,ITS ON THE SIDE OF FUSES 8,9,10 AND 11 ....... we all have had one give us a NIGHTMARE and this is it for me .  my tools are  POWER PROBE -PP3 ,and PP (THE HOOK  and power probe  ECT - 2000 , DVMM , TEST LIGHTS , both kinds regular and computer safe ,,AND A BLURDRIVER AS MY SCAN TOOL . I HAVE 1000'S OF PAPERS WITH DIAGRAM, SCHEMATICS , ALL SORTS OD DIAGNOSTIC INFO ,MOSTLY FROM ONLINE CHILTON , AND SEVERAL FROM MITCHELLE 1 . I HAVE ACCESS TO MITCHELLE  1 PRO DEMAND NOW , SO IF I GET ANY REFERENCE HELP FROM YOU PAUL OR OTHERS , I CAN LOOK IT UP AND FOLLOW ! ANY HELP ON THIS MATTER IS GREATLY APPRECIATED . ITS BEEN PARKED 11 MONTHS , PLEASE HELP .
Last edit: 5 years 2 months ago by Rickyrick.
5 years 2 months ago #50433 by Cheryl
Post wiring diagrams. Power distribution ones that fuse 10 feed.
5 years 2 months ago #50434 by Cheryl
What fuses does the relay feed?? Show power distribution of what relay feeds
  • Rickyrick
4 years 7 months ago #55179 by Rickyrick
march 21, 2022 , still parked , this is my worst nightmare . to add to this write up i want to say ,i remember getting to my lacrosse ,when i click the remote to open the door i heard this machinegun noise coming from under the hood . it does this when i reconnect the battery , open the doors or pop the trunk . i have done many test including running a jumper wire to activate the starter ,and , starter works . on the fuel pump issue ,i do hear it run for a couple of seconds when i push the start button . so my starter and fuel pump are good . im sorry im just getting back to this people especially Cheryl who was my only reply .po23f states there is an open in fuel pump secondary system , i wish i knew more about what the secondary system is ? i wish i totally understood and knew how to use the pp3 and my ect-2000 short finder . here is the 2 codes that still come up UO100 AND PO23F .MY #10 FUSE KEEPS BURNING ,ITS ONE OF THE ECM FUSES . this car has really stressed me out ,i really need serious help here ,i wish i could afford to tow it to scanner danner's school so he and his awesome students could tinker with it , it would def be very interesting to say the least LOL ! ANOTHER STRANGE THING IS WHEN I JIGGLE CONNECTION X108 IT MAKES MY LIGHT ON MY SHIFTER STAY ON AND MAKES MY GAS GAUGE EITHER WORK OR STOP WORKING . ANY HELP FROM ANY OR ALL OF YOU INCLUDDING THE TECH gOD SCANNERDANNER IS greatly honored ! thank you all for your help .
  • Rickyrick
4 years 2 months ago #57224 by Rickyrick
please help scanner danner students ,himself , Cheryl and anyone else .Cheryl are you still up to helping me on my worst nightmare of my life , my buick lacrosse is still down .i am fired back up to finally trouble shoot again . it starts with UO100 AND PO23F CODES ,NO CRANK NO START . VIOLENT FAST CLICKING CAN BE HEARD AT TIMES WHEN I CONNECT BATTERY , OPEN DOORS OR TRUNK ,UNLOCK OR LOCK DOORS .this also stops when i disconnect the X108 connection .looks like the push button starter does it job with turning on car but no crank , no start and the check engine light flashes super super fast . my # 10 fuse keeps burning also .i have access to pro demand so i am able to look up stuff .i wish i could bring my car to yallz school for danner and his students to tackle lol !!! THIS WOULD BE THE ULTIMATE QUIZ FOR PROBLEM SOLVING !!!
  • Rickyrick
4 years 2 months ago #57268 by Rickyrick
#10 fuse , sorry so late Cheryl !
  • Rickyrick
4 years 2 months ago #57269 by Rickyrick
this car is driving me crazy lol .
4 years 2 months ago #57366 by rpd1125
I ran into a Buick with similar problem. Seems like your fuel pump control module is burned out on you. It’s located in right rear corner of trunk. Pretty simple to get to. Here is a diagram that may help. You may find a burned connection Almost like when you find a burned connection at a blower motor resistor.
Anyway. You can manually run the pump without the module. Simple jumper the terminals as drawn out on diagram below. Dark Blue to Black( this will complete ground to fuel pump). And then with a second jumper. Go Red/violet to Grey. ( this will supply battery voltage to fuel pump). Do all this with fuel pump control module disconnected okay. This fuel pump module can pull enough amperage to cook a pcm. Keep us posted
Hope this helps
  • Rickyrick
4 years 2 months ago #57387 by Rickyrick
rpd1125 thank you so much for the tip my friend , tomorrow i will bring my battery to auto zone for a full quick , when done , its weird the noise clickicking noise that comes from under hood, when i connect battery ,use remote , open trunk if i leave battery connected ,it will do that clicking every few minutes ! i hear the fuel pump in tank run for a few seconds when i sometimes try to start , i hear the high pitch sound of the secondary high pressure pump at the engine run , thats why all this made no sense ! its almost 2 years its been down , i even have more than 3/4 fuel in tank .when i messed with con -X108 and A and B conn at pcm ,sometimes it makes my gas gauge work again ...I TRIED USING MY OUTDATED ECT 2000 WHICH WAS A COMPLETE NIGHTMARE .LOL !!! i cant wait to buy the book and take the class , i been without work all this time due to an injury and i soon expect my surgeries and back to work hopefully before "SHTF" and the end of days and end of world as we know it come upon us ! GOD BLESS YOU AND ALL THE STUDENTS AND PAUL HIMSELF !
RICKYrick i humbly remain ~
4 years 2 months ago #57426 by Noah
+1
  • Rickyrick
4 years 2 months ago #57455 by Rickyrick
SO TWO WHOLE YEARS EXAAACTLY THIS MONTH , COULD THE CLICK RELAY BE BURNING THE FUSE .YOU MAY ASK ,WHAT CAUSES A RELAY TO OPERATE LIKE A MACHINE GUN ? .SET A RELAY FOR TEST , NOW WITH HOT WIRE , BARELY TOUCH IT ON THE CORRECT LEG .YOU MAY TRY SLIDING IT BACK AND FORTH TOUCHING IT SO EVER LIGHTLY . WHEN CONNECTION ISNT SOLID ,IT WILL CAUSE IT TO CLICK OFF AND ON VERY RAPIDLY !so ,you can see a connection thats hanging on by 1 or 2 strands , corrosion ,fretting , etc.etc.etc. maybe a semi loose ground could def do this to a relay right ? this stupid # 10 fuse feed three ign wires to the PCM !!! help me JESUS !!!! LOL
  • Rickyrick
4 years 2 months ago #57456 by Rickyrick
PRODEMAND LABELS THE RELAY THAT SUPPLIES F10UA #10 UNDERHOOD FUSE AS KR-71 NOT KR75 AS ONLINE CHILTON AS DESCRIBED ! SO CAN WE SUSPECT THE CLICKING FAST RAPID ACTION OF RELAY 71 BE A OR ONE OF THE CULPRITS ? if i wasnt a believer , i would def sell my soul to fix this prob lol lmao !!!!! i have never had such a problem with an automobile in my entire life !!!! so most of this time , im looking at fuse ten how it supplies power to three wires to ign on PCM . the fuses doent burn unless KR71 is left in . this relay also feed fuses 8, 9 , 11 and 47 . just a thought ,if it was the relay causing the prob it would burn all the other fuses also .
