Ford Explorer stuck in park
- gnx547
5 years 2 months ago #50331
by gnx547
Ford Explorer stuck in park was created by gnx547
2010 Ford explorer wont shift out of park. This happened before a few yrs ago and the shift interlock module was bad. I'm thinking the module is bad because it's Dorman and usually doesn't last long. The brake light switch is good, the brake lights do come on.
I'm moving the shift solenoid lever to by pass it so I can move the lever into gear. As I'm doing this the shifter won't move into gear. Does this sound like a shifter assembly problem? I should be able to bypass it but the shifter is still stuck in park. Any ideas?
5 years 2 months ago #50352
Replied by Tyler on topic Ford Explorer stuck in park
I'd want to check some scan data first, before making a shifter call. Mostly I'd like to see what the BRK_SHIFT PID does with the key on and your foot on the brake. If it shows Active, I'd check power and ground at the shift interlock solenoid, then change it.
But you're saying that the shifter doesn't move, even when using the bypass? That almost sounds like a seized cable to me. If you pop the cable loose of the shifter, does it now move? If not, the problem is in the shifter.
- gnx547
5 years 2 months ago #50370
by gnx547
Replied by gnx547 on topic Ford Explorer stuck in park
I have an Actron scanner and not sure if it shows brake shift pids, but I'll check and see.
I'll remove the cable from the shifter and see if the shifter moves then. Thanks!
- gnx547
5 years 2 months ago #50397
by gnx547
I disconnected the shifter cable from the shifter and I'm able to move the shifter when I bypass the shifter lever. Sounds like the shifter cable is bad or a problem with the transmission.
I'll disconnect the cable from the transmission and see if I can shift it by hand.
- gnx547
5 years 2 months ago - 5 years 2 months ago #50527
by gnx547
The transmission is a 5R55S. I disconnected the transmission cable from the transmission and I'm able move the shifter through the gears. I feeling no binding in the cable.
I tried to manually shift the transmission into gear from the lever on the transmission with my hand and it wont move out of park.
Could a bad transmission range sensor cause this? I'm thInking if the sensor is bad I still should be able to manual shift the transmission into gear?
I'm thinking this is a transmisson problem and something internal is jammed up preventing it to shift out of park. Would you agree?
Last edit: 5 years 2 months ago by gnx547.
- ontheriver
- Thank you received: 16
5 years 2 months ago #50529
by ontheriver
Replied by ontheriver on topic Ford Explorer stuck in park
Yes, internal, can you have someone rock the vehicle while you try to shift, Wondering if the parking pawl is binding,to be safe do this from the drivers seat
- gnx547
5 years 2 months ago - 5 years 2 months ago #50691
by gnx547
We rocked the vehicle several times and it did get out of park! The parking pawl is broken. When the shifter is in park it just rolls. I wanted to move the explorer now it won't start, no crank no nothing. What a headache!
