testing plugged exhaust
- robert.lesaca
- Thank you received: 19
5 years 2 months ago #50320
by robert.lesaca
testing plugged exhaust was created by robert.lesaca
just a general question...can one use and INFRARED gun to determine which among the upstream and downstream exhaust is plugged instead of drilling holes per Scannerdanner method of drilling holes ?
thank you...
thank you...
- Hardtopdr2
- Thank you received: 150
5 years 2 months ago #50360
by Hardtopdr2
Replied by Hardtopdr2 on topic testing plugged exhaust
You don't have to drill holes you can pull the upstream o2 sensor and make an adapter to hook to your pressure gauge.
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 2 months ago #50362
by juergen.scholl
Replied by juergen.scholl on topic testing plugged exhaust
Is the idea behind your question to detect that the cat outlet temperature would not be the typical 100 degrees F higher than the cat inlet temperature'? If so you might detect a completely clogged converter but I would not consider it a conclusive stand alone test.
Pulling an O2 sensor wouldn`t be my preferred testing method neither. Often times O2 sensors are placed in diffiicult to reach places, they are badly rusted and may break in the process or even the converter threads could strip.
A vacuum gauge reading of the intake manifold is a quick and dirty test ( on map sensor engines use this sensor), a secondary ignition test is almost fool proofed if you know what to look for. In-cylinder pressure captures will proof exhaust restriction as well.
When suspecting a clogged exhaust/cat causing a no start situation you may want to pull out a plug; the engine will fire up and at least you can pull it into the shop.
- robert.lesaca
5 years 2 months ago #50378
by robert.lesaca
Replied by robert.lesaca on topic testing plugged exhaust
I meant in the event upstrram 02s are not accesible...
- jreardon
- Thank you received: 198
5 years 2 months ago #50380
by jreardon
Replied by jreardon on topic testing plugged exhaust
Well in that case, seeing as to how expensive cats are and not having to make a bad call on one, I think drilling holes would be appropriate in your case to take direct measurements.
- jreardon
5 years 2 months ago #50381
by jreardon
22 minutes in
