ECV A/C Compressor
  • rankin2
  • rankin2's Avatar Topic Author
5 years 2 months ago #50197 by rankin2
ECV A/C Compressor was created by rankin2
Hello First post, I am working on a 2016 Hyundai Accent 1.6l I replaced the A/C compressor, condenser and dryer, and expansion valve around a month ago. All working great. About three weeks later customer said A/C quit. No codes in ECM manual A/C. Hooked up my 4 seasons Temp Select, when I push A/C button get a reading of 93% for about 5 seconds, then it reads Zero%. I can manually control compressor at about 35% and 60 %, I have replaced the A/C module with new Hyundai part and have found no problems with wiring to Compressor. A/C high side around 220 and low around 50 outside temperature 90 degrees . I have also changed the evaporator temperature sensor and tested the ambient temperature sensor, What is shutting off the Compressor. 936-594-2004 Thanks in advance RankinĀ
