2015 Ford Transit 150 3.7L P0016 CAM-CRANK CORRELATION BANK 1 SENSOR A
5 years 3 months ago #49835 by Red X
Been dealing with a 2015 Ford Transit 150 P0016 code. I dont believe i have a timing issue based on symptoms. Vehicle starts fine every time, symptoms is MIL and it starts to show somewhat lack of power or hard acceleration at 40 mph. It struggles to get to 60 mph but it will. Anything above 60 it cant without downshifting a gear and when it does, RPMs are 3500 and start to increase with vehicle speed. It doesnt want to shift to the next gear. I believe it is a transmission related issue, but since its giving a CAM CRANK Code. i decided to get a waveform. i dont have a known good to compare. If any body does, i would greatly appreciate it and also any second thoughts about this Ford Issue. Also both VVT solenoids on bank 1 have been replaced and transmission fluid level and condition has not been checked. Please and Thank you.
