Baffled Canadian!!.
- Raydes 050
5 years 3 months ago #49808
by Raydes 050
Baffled Canadian!!. was created by Raydes 050
Hello Everyone, Love the Show,
I'm a diy mechanic with a 1997 Ford F-150, 4.2 V6, rebuilt 8000km ago and when I bought it, it had several problems, which I have fixed. Thanks to Scanner Danner I found a hidden vac. leak that I am sure previous mechanics did not find due to the location and the rusted bolts that were never taken off!! It was behind the battery case next to the firewall, a line right out of the vac. tank. Anyway after replacing one o2, B2S1, because it was reading straight lean with no response, I now have a rich condition that I can't make sense of. Before with the vac leak, I had lean and rich codes now I am just getting rich codes and still goes into closed loop fault after a couple of minutes, then open loop fault. While it is in closed loop at first, all 4 O2.s are at .8, to .9 volts and the computer is taking away fuel -20 on both banks, also I should mention that the truck starts great, runs great, except for the black smoke due to rich condition! I did a compression test and that checked out, vacuum on the engine shows 17 or 18 hg steady, checked for plugged exhaust and that seems good, No backpressure, I don't have a long term FT numbers for some reason, not sure if its because it never stays in closed loop long enough for it to get there? or some other reason? I have excellent fuel pressure and the regulator works as it should with no leaks, did an injector balance test and they all drop 6psi, also took them all out and cleaned the screens & checked to see if maybe one was stuck or something, ran cleaner through them with no issues! Checked and replaced EGR, PCV, Purge solenoid. I was concerned about the MAF readings before, so I replaced the sensor and the one I bought from Rock Auto is a BSE unit and it is reading the exact same at idle which is between 7-9 grams/sec which I think is high. I'm pretty sure it should be around 4 or 5 for this motor? but the last time I took it out for a drive, it did not go higher than, I think, 120 or 130 g/s! and the old unit 160 or so. But these are the codes it threw, P135, P155, P141, P161, P1132, P1151 It has a K&N cold air intake. All the other numbers seem good, Intake Temp, Tp, load, cool. temp, My timing also I am not sure if its normal, but it fluctuates between 14 and 24 at idle? My manual says it should be 15 deg.BTDC at idle, but I am thinking that the refresh rate on my code reader might not be fast enough? Is my timing wrong, or could it cause the rich condition? Its set by the ECM and cant be adjusted so,,, anyway I really don't know where to go next ? I am waiting until I can afford a oscope and a bi-directional scanner to be able to do more tests but until then.... Another question I have is, on the 5v ref for the MAF i get 5.8 volts? Is this normal or could that be why my Maf readings are skewed?? Again this Canadian is a big fan of the show and have learned alot, I am in school now for my red seal in Plant Maintenance and will probably buy your book and join your classes when time allows! Any feedback would be greatly appreciated, Thanks
- Raydes 050
5 years 3 months ago #49811
by Raydes 050
Replied by Raydes 050 on topic Baffled Canadian!!.
Hi again everyone, Ray here, owner of the long post! I forgot to ask, what I was thinking, would it be possible for my situation, could the ECM have been setup to compensate for that vacuum leak that I found? Maybe the tech who rebuilt the engine couldn.t find that leak and changed the pulse width of the injectors!! I did a KAM reset each time I fixed something, but does that fix it? Not sure,,, Any thoughts on that? Thanks
- Hardtopdr2
- Thank you received: 150
5 years 3 months ago - 5 years 3 months ago #49812
by Hardtopdr2
Replied by Hardtopdr2 on topic Baffled Canadian!!.
Fuel trims will take a bit to relearn. Also some of those year Ford trucks had a maf and a map sensor and recommend check map sensor as well as intake air temp sensor readings.
To check base timing you can disconnect the pip wire connector should be gray with a single wire coming from distributor.
Last edit: 5 years 3 months ago by Hardtopdr2.
5 years 3 months ago #49818
Replied by Andy.MacFadyen on topic Baffled Canadian!!.
I haven't really studied your post but K&N Cold Air Intake immediately raised alarm bells.
These are prime suspects to cause lean air-fuel ratios.
- Raydes 050
5 years 3 months ago #49823
by Raydes 050
Thanks for replying guys! No MAP sensor on this one, and Intake Air is bang on. But maybe I just haven't driven it enough yet for the computer to relearn the new parameters! I've only driven it once since I put in the new MAF and fixed the vacuum leak.
- cj1
- Thank you received: 12
5 years 3 months ago #49829
by cj1
Replied by cj1 on topic Baffled Canadian!!.
Fix these codes first.
May well be causing fuel trim problems.
Time to create page: 0.691 seconds
