Does a 2011 Dodge dakota has a tpms reset buttom..??...If it does...where is loc
  • angelcoamo44
  • angelcoamo44's Avatar Topic Author
5 years 4 months ago #49543 by angelcoamo44
Does a 2011 Dodge dakota has a tpms reset buttom..??...If it does....where is located..??...Or does anyone knows how to turn off the tpms light on the dashboard...??
5 years 4 months ago #49553 by Noah
From what I can gather from service information, there is no button or switch to reset the system.
If the tires are all at the proper inflation pressure (some times a full size spare will have a sensor also), and the warning lamp is still on, then you will need to retrieve the trouble codes to determine where the fault in the system is to fix it.
5 years 4 months ago #49575 by JHAnderson
Does the light flash at startup? This would indicate a faulty sensor or other electrical issue within the system (flashes at startup and then remains solid). If on solid at startup this would be a low pressure issue. If only low pressure simply inflate to the pressure listed in the door sticker and drive, I like to inflate 1lb over cold specifications.
The following user(s) said Thank You: Noah, angelcoamo44
Time to create page: 0.266 seconds
