93 Toyota 22re injectors not firing
  • Acuello
  • Acuello's Avatar Topic Author
5 years 4 months ago #49499 by Acuello
93 Toyota 22re injectors not firing was created by Acuello
I have power to injector the the ground control side also has power. I check the ground terminal on coil and also has power. Any ideas where to start looking for a short ?
5 years 4 months ago #49502 by Doodah14
Replied by Doodah14 on topic 93 Toyota 22re injectors not firing
Most vehicles have power to the injectors any time the ignition is on. The computer sends a ground to the injectors to fire them. So if you check the ground when the engine is not cranking or running it will show power on the ground side. Same with the ignition coil. Use a Noid light or make a light usinging any 12 v bulb. Plug the light into the injector plug. It should flash while cranking. If your not getting any injector or coil pulse. Check your scan data and see if your getting a rpm. It won't be much, maybe 150 while cranking. If not you may have a bad crank sensor.
